icer Banned 2,335 Member For: 15y 10m 5d Gender: Male Location: Aspendale, Vic. Posted 16/01/11 03:46 AM Share Posted 16/01/11 03:46 AM sure if it justified the costs of 1300+ for a x3 + tune. or a j3 + tune is like 500$. Not like there will be a 20rwkw diff between the 2. Link to comment https://www.fordxr6turbo.com/forum/topic/68662-what-kws-are-you-getting/page/2/#findComment-1072637 Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 5m 4d Gender: Male Location: North West Hot Hell,VIC Posted 16/01/11 07:27 AM Share Posted 16/01/11 07:27 AM Dont they only use J3 chips on the E series ,Isnt that why we all initially went with flash tuners on our B series cars ? Link to comment https://www.fordxr6turbo.com/forum/topic/68662-what-kws-are-you-getting/page/2/#findComment-1072671 Share on other sites More sharing options...
xhxrsix Member 174 Member For: 18y 6m 15d Gender: Male Location: Melbourne Posted 16/01/11 01:46 PM Share Posted 16/01/11 01:46 PM Can't use a J3 on a BA... and they have camS not just a cam. lol.My old BA XR6 ute had usual stuff.. intake/full exhaust, t5, 3.7 gears, cams + tune and only made 170~rwkw.. but ran a 14.0 1/4 mile. Link to comment https://www.fordxr6turbo.com/forum/topic/68662-what-kws-are-you-getting/page/2/#findComment-1072821 Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 7m 24d Gender: Male Posted 17/01/11 12:10 AM Share Posted 17/01/11 12:10 AM no need for a x3,, a vcm tune would be fine Link to comment https://www.fordxr6turbo.com/forum/topic/68662-what-kws-are-you-getting/page/2/#findComment-1072902 Share on other sites More sharing options...
banddriver Member 20 Member For: 14y 11m 11d Posted 17/01/11 04:08 AM Share Posted 17/01/11 04:08 AM theres a member of Ford Forums in the Bserise area making over 250 rwkw. Link to comment https://www.fordxr6turbo.com/forum/topic/68662-what-kws-are-you-getting/page/2/#findComment-1072972 Share on other sites More sharing options...
Trav199 Member 126 Member For: 14y 4m 5d Posted 17/01/11 08:53 AM Share Posted 17/01/11 08:53 AM hahaha well offically im making 247rwkw.. Yet to recieve dyno sheet of more.. Link to comment https://www.fordxr6turbo.com/forum/topic/68662-what-kws-are-you-getting/page/2/#findComment-1073102 Share on other sites More sharing options...
Stink Senior Moron Donating Members 1,059 Member For: 16y 29d Gender: Male Location: Sunshine Coast..... somewhere Posted 17/01/11 10:27 AM Share Posted 17/01/11 10:27 AM Ya gotta be happy with that Trav Link to comment https://www.fordxr6turbo.com/forum/topic/68662-what-kws-are-you-getting/page/2/#findComment-1073136 Share on other sites More sharing options...
Anchor Member 270 Member For: 15y 2m 13d Gender: Male Location: Rockhampton Posted 17/01/11 04:11 PM Share Posted 17/01/11 04:11 PM Sounds like a monster too Trav.. Zane reckons he'll get a bit more out of it once they get the tune and exhaust sorted.. Link to comment https://www.fordxr6turbo.com/forum/topic/68662-what-kws-are-you-getting/page/2/#findComment-1073212 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 4m 8d Gender: Male Location: QLD Posted 17/01/11 05:06 PM Share Posted 17/01/11 05:06 PM I know this is a na discussion but I had a na beat my BAXR6t with To4z, hdi cooler, xforce exhaust, Plazmaman plenum, seimens injectors etc eta. If only my turbo to ic hose didn't blow off. Serious now,Some good numbers there for those na's. Do suggest to either go with a decent tune from either sct flash, vfm or snipper to get the most from your cars. Pretty much the setup OP is running except his clutch. If your chasing dyno numbers stay with the manual, preferably a t5 as it has smaller internals so should not rob as much power. A bit of intake porting would help as I'm pretty sure the flow percentages are same as T heads and it is suited for boost applications. You want as close as possible a 1% intake flow to 0.75 exhaust flow in a na application. Research your exhausts, pacemakers work well, find a cat that flows well, I have had great results from race magnum mufflers in the past mind you there are plenty of good ones on the market these days. Don't go any bigger then 2.5 or you will loose to much bottom end, make sure you use mandrel bends and that all joins are flush for a uninterfeared flow path. You want to find the best location on the car for the cold air intake as the more air pressure the better the cylinder fill. Your intake needs to be as smooth as possible with least bends possible and the straighter the better. Makes it hard where the throttle body is positioned, I have seen people reverse it so it points towards the strut tower, it's a good option as you will shorten the intake tract as well get rid of the usual 180 bend. Other then that fit a scoope on bonnet to flow through filtered airbox straight into throttle body in it's original position. Keep in mine the quicker the air can get in to the cylinders the more it fills it, then the more fuel can be added to give more power. The exhaust needs to be able to draw as much from the cylinders as it can. A lot of people get it wrong here as they think big large ports so you can fit more through, the problem is in doing so you lose air speed, which causes the cylinders to to fill or empty as much volume. Mine you if building a engine to rev extremely high large ports are the choice, just lose all low down power though. Hope helps some of you na guys in your power hunt. Link to comment https://www.fordxr6turbo.com/forum/topic/68662-what-kws-are-you-getting/page/2/#findComment-1073214 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 4m 8d Gender: Male Location: QLD Posted 17/01/11 05:29 PM Share Posted 17/01/11 05:29 PM Also don't bother to try building these i6's to rev past 6000 as you may get minimal power gain but at a high risk. The oil pump can hydraulic itself to pieces (fixed by improving oil releif)The rods and crank are both of cast iron and not strong enough to cope with sustained high revs. As well being a low rev torque monster with it's long stroke small diameter piston you will find piston speed to be to excessive at higher then 6000rpm. Also upgrade your valve springs as it will help with valve control. Link to comment https://www.fordxr6turbo.com/forum/topic/68662-what-kws-are-you-getting/page/2/#findComment-1073215 Share on other sites More sharing options...
