Scrubbing 20"S On Ute
antonioxr
  • Member For: 15y 8m 27d
hey got some 20's put on my ute they are 8.5 wide on front and 10" on the rear the rear are 275's and the back left side only seems 2 be scrubbing wile driving over slite bumps in rd etc anyone else had this prob ?? and any solutions? im pretty sure they trimmed the inner lip but cant roll the gaurds cause they are double lipped
Edited by antonioxr
  • A much better forum
  • Member For: 16y 6m 10d
I have 20x10 on the rear of a sedan that is lowered about 8-10cm...
The back of the guard seems to hit a little when heavy in the back... Or hit a huge bump... Might need to get it trimmed... However mine are rolled... Otherwise they would bash the sh*t out of the guards...
  • The Cleaning Dudes Ute
  • Member For: 18y 9m 21d
The main problem with utes is the rear axle doesn't have a panhard rod, theres not alot keeping it centre.
They'll usually sit moreso to the passenger side-centre.
What offset are the rears?
Is it rubbing on the inner or outter edge of the rim? - If its happening on the left side, I'd assume the outter edge?
  • Member For: 14y 10m 23d
Yeah that's an awesome feature, your left side will sit closer to the guards..
I have 18x9.5's on the back with some serious offset. Had to stretch 255's over them so I didn't scrub and pop the fuel cap open on every bump.
You shoulda went 9.5's on the front :3gears:
My 9.5 rears are 38? offset with 15mm bolt on hubcentric adapters. With a 255/35/18 on them. Rim sits kinda even with the guard, tyre goes under. Just doesn't scrub on the left.
I have a sh*tload of clearance on the inside of the rims and my ute is pretty much on the bump stops. Also got a big rear swaybar, don't know if that has any effect on scrubbage.
  • Member For: 16y 10m 13d
I have 10.5s (by 22") to go on mine, I'll just leave it with a panel beater to make them fit, wella.
that's basically a +23 offset, except yours will have more clearance for brakes because of the original +38 offset. However I wouldn't want to be in your shoes if you have a prang lol.
Is that how wide those 22's of yours are? Let me know how you go with that...
I'm considering a bit of guard work to make 295/35/19 Toyo R888's actually fit WELL
  • 3 months later...
