Wtf Is That Noise?
Pube
  • Member For: 17y 7m 12d
My engine has recently developed a high pitch noise mostly noticable at idle. You can hear it inside or outside the cabin with the bonnet closed. Its not turbo related as I can make out its comming from around the throttle body/inlet manifold and towards the front of the engine. Almost sounds like a small electric motor just about to explode...
The first time I heard it was when I was giving her a hoot on my favourite private rd. It started very loud but became a bit quieter when I began to slow down and cruise to let the engine cool. Now its just makes the noise when you drive to the shops. I have checked all plumbing but I cant pin point where the hell it is comming from.
Anyone experienced a similar noise?
  • Member For: 20y 10m 11d
does it change witht he rpm or stays consistant ?
Could be the serpentine idler tensioner if it changes with the rpm.
When I noticed the noise initially, the noise seemed to be there when I was coasting then dissappeared when you touchted the throttle slightly. I changed both idler and tensioner pulleys about 6 months ago but I will remove the belt tomorrow to rule that out.
  • Member For: 21y 3m 22d
I believe my alternator is shagged, I get a whine or high pitched squeel all the time from it and believe it happened when my water pump shat itself and poured over the alternator?
I get massive alternator whine through the cars electrics now also.
  • Member For: 16y 1m 4d
Sounds to me like a bearing has shat itself in one of the pulleys along the belt.
Get a long screwdriver and hold the tip against each area (tensioner, water power, alternator, power steering etc) you should be able to find it quickly.
If it was a boost leak it would probably be getting louder not disappearing as revs climb.
Just an idea
