  • Replies 65
Posted Images
  • Member For: 18y 11d
At what sort of power levels is it worth considering a plenum, isn't the factory unit not to bad?
  • Member For: 17y 9m 19d
how about snort plenums? does away with the std manifold and uses the short tapered runners instead....
I dont think that many people are using them, probably because they might be unproven in these forums, but looks like sex and are around the $1300 mark
has anyone got any results or feedback on one of these plenums?
This is the plenum I'll be using on my big-banger project. Looks absolutely awesome. And with those tapered runners, should work like a charm for making big power. I can't wait to get this gear on my car.
  • Member For: 17y 4m 18d
a good plenum frees the breathing up on any engine, whatever power. good thing to have when making big power on stock internals. hehe.
  • Member For: 19y 9d
The best plenum depends on what the owner is looking for, As mentioned the Nizpro plenum has been put through emission testing in conjuction with other Nizpro components and it comes complete with everything you need to fit it on the car and have it running, this includes wiring extension harness's studs, nuts vacuum fittings, etc etc.
We have had a car go through emission testing complete fitted with Nizpro plenum, cooler, injectors, air intake, 12 lb actuator, ported turbo with larger flapper, walbro intank pump, The owner showed them his paper work showing the emission testing on the components fitted to the car, they checked the car ran a sniffer up the exhaust and sent him on his way with a pass.
Not sure if any other manufacturer has paid to put their product through emission testing
Edited by ratter
