6BOOST Gold Donating Members 139 Member For: 17y 4m 7d Gender: Male Posted 23/12/10 12:11 PM Share Posted 23/12/10 12:11 PM I'm not sure if anyone has told you different but the stage 4's will work perfectly with VCT, we have done several cars with them with no issues, this may give you the best of both worlds.6BOOST Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/7/#findComment-1066220 Share on other sites More sharing options...
PSI40L Member 175 Member For: 22y 5m 13d Posted 24/12/10 12:44 AM Share Posted 24/12/10 12:44 AM Kyle just a quick question when using the stg 4 cams with the vct do u guys play with the cam timig settings through the vct or u dont touch it .I have heard the phasers dnt extend that far out hence the idea of the verniers among other things .I have played with cam timing with std cams and there is a good pik up in midrange and top figure. If so how much are the gains just seeing if its worthwhile putting on my streetcar Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/7/#findComment-1066304 Share on other sites More sharing options...
darios typhoon Member 73 Member For: 15y 11m 29d Gender: Male Location: northern beaches Posted 24/12/10 06:11 AM Author Share Posted 24/12/10 06:11 AM On 23/12/2010 at 12:11 PM, 6BOOST said: I'm not sure if anyone has told you different but the stage 4's will work perfectly with VCT, we have done several cars with them with no issues, this may give you the best of both worlds.6BOOSTkyle did it pull peak power past 6000rpm and how was the bottom end I suppose it depends on the turbo used but a before and after comparison would be nice with the stage4s Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/7/#findComment-1066366 Share on other sites More sharing options...
6BOOST Gold Donating Members 139 Member For: 17y 4m 7d Gender: Male Posted 24/12/10 10:11 AM Share Posted 24/12/10 10:11 AM Well Jamie is the resident tuner, so jamie if you read this let everyone know what we do with cam timing, I mainly instruct the 1's and 0's for af ratio, boost and timing on the big cars as I'm the one responsible for them, but he can tell you what we do with cam timing. I don't think you'll find a vast amount moving them around, bigger cams no matter which way you swing it are going to compromise bottom end, unless you only do a very mild upgrade. As far as making power past 6000rpm, we haven't done anything with such a small exhaust wheel and housing as your darious, everything with cams has been GT42 style turbo kits. You have to keep in mind that its not just camshafts that limit peak power rpm potential, you have engine VE, turbine restriction, port velocity and a mutlitude of other factors to consider. 6BOOST Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/7/#findComment-1066412 Share on other sites More sharing options...
Phoontastic Donating Members 262 Member For: 19y 3m 27d Gender: Male Location: Canberra Posted 25/12/10 12:02 AM Share Posted 25/12/10 12:02 AM On 23/12/2010 at 12:11 PM, 6BOOST said: I'm not sure if anyone has told you different but the stage 4's will work perfectly with VCT, we have done several cars with them with no issues, this may give you the best of both worlds.6BOOSTKyle, this is what I was wondering. It would be great if Jamie could enlighten us as I think it will help quite a few people on our continuing journey to develop each of our examples of one of the best six cylinder engines in the world (IMHO). Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/7/#findComment-1066506 Share on other sites More sharing options...
PSI40L Member 175 Member For: 22y 5m 13d Posted 25/12/10 12:16 AM Share Posted 25/12/10 12:16 AM I havent played with the verniers yet but the last windsor I built with an adjustable cam gear I built with a big cam just changed the power curve and where things start to happen there were no in crease in peak power .I know the std cams do ike timing in the m and the increases are beneficial Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/7/#findComment-1066509 Share on other sites More sharing options...
darios typhoon Member 73 Member For: 15y 11m 29d Gender: Male Location: northern beaches Posted 25/12/10 01:23 AM Author Share Posted 25/12/10 01:23 AM On 25/12/2010 at 12:16 AM, PSI40L said: I havent played with the verniers yet but the last windsor I built with an adjustable cam gear I built with a big cam just changed the power curve and where things start to happen there were no in crease in peak power .I know the std cams do ike timing in the m and the increases are beneficialI have tried when I first put them in I had 2 deg advanced on the inlet and it lost bottom end then jim put it back on zero and picked up the bottom end and alot more light throttle response so we are going to try more retard on both and see what we get.this will be done early in the new year. Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/7/#findComment-1066516 Share on other sites More sharing options...
supercharged88 Member 153 Member For: 16y 10m 4d Gender: Male Location: Far Nth QLD. Posted 25/12/10 09:38 PM Share Posted 25/12/10 09:38 PM Firstly I must say the following is just comments on how I setup cam phasing.This is aimed at the "DO IT YOURSELFER"not any any workshop or experienced engine builder/tuner.Do not attempt any of this unless you an apt understanding of engines and tuning.You can create problems and at worst destroy your engine.When ever I use vernier cam gears in an engine I have built and tuned I do the following.Making guesstimated settings to valve timing is taking the long way around.Dial cams in at 0, do a base line tune and dyno run, check peak power and start fininsh of TORQUE curve.I then degree the cams in to manufacturers specs and do another run.Check the difference between the 2 runs.If the dyno you are using allows it, do an overlay of both runs to make analysis easier.I then start to play with the valve timing events in the quest for optimising torque etc.Having true base line settings to work from,EG: dialed in at 0 and then degreed at manufacturers specGives you an accurate starting point.If it all gets to messy and hard to go any further simply use the settings that yielded the best results 0 or manufacturers spec.Remember no two engines are ever the same, what works on one maybe completely wrong for the other as far as OPTIMISING goes. Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/7/#findComment-1066654 Share on other sites More sharing options...
Phoontastic Donating Members 262 Member For: 19y 3m 27d Gender: Male Location: Canberra Posted 28/01/11 11:15 AM Share Posted 28/01/11 11:15 AM Dario, any progress on experimenting with the cam timing?? Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/7/#findComment-1076244 Share on other sites More sharing options...
darios typhoon Member 73 Member For: 15y 11m 29d Gender: Male Location: northern beaches Posted 28/01/11 09:12 PM Author Share Posted 28/01/11 09:12 PM On 28/01/2011 at 11:15 AM, Phoontastic said: Dario, any progress on experimenting with the cam timing??yes mate did plus 2 on inlet and zero exhaust lost bottom and top then went -2 on both and it held the top end for a bit longer past 6000 rpm but no extra power and it lost bottom end from the inlet cam being on -2 so I put it on 0 on the inlet and that was the best it could dothe next week I put the standard bf cams and vct gears back on and it went straight to 490 kw at the same boost heaps better bottom and peaked at 6000 rpm better mid as well stock bf cams worked the best with the turbo combo that im using those other cams in my opinion are crap they do nothing . Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/7/#findComment-1076329 Share on other sites More sharing options...
