darios typhoon Member 73 Member For: 15y 11m 29d Gender: Male Location: northern beaches Posted 13/08/10 08:14 PM Author Share Posted 13/08/10 08:14 PM new motor should be about 3 weeks but then have to wait for jim to come back from holidays then push it a liitle harder. may be 700kw Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/6/#findComment-1032453 Share on other sites More sharing options...
tray_182005 Member 1,226 Member For: 15y 9m 23d Gender: Male Location: Wee Waa/NSW Posted 13/08/10 11:06 PM Share Posted 13/08/10 11:06 PM Look forward to it mate Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/6/#findComment-1032466 Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 8m 22d Gender: Male Location: Mildura Posted 17/08/10 10:13 AM Share Posted 17/08/10 10:13 AM fmd if I win the lotto im trucking my phoon to you guys, haha instructions saying "make it scary!" Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/6/#findComment-1033248 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 19d Gender: Male Location: Loitering in SEQ Posted 19/12/10 01:24 PM Share Posted 19/12/10 01:24 PM Has anything happened with this animal since the new engine went in??? Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/6/#findComment-1065023 Share on other sites More sharing options...
darios typhoon Member 73 Member For: 15y 11m 29d Gender: Male Location: northern beaches Posted 21/12/10 05:43 AM Author Share Posted 21/12/10 05:43 AM yes engines in running in just did tune with with stage 4 cams and not very happy with them but going to do some cam timing changes and if it performs the way they should they stay in if not stock cams go back in .jim got 480 kw with pump fuel so will see in about two weeks hows your one going quick 1. Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/6/#findComment-1065410 Share on other sites More sharing options...
tray_182005 Member 1,226 Member For: 15y 9m 23d Gender: Male Location: Wee Waa/NSW Posted 21/12/10 07:47 AM Share Posted 21/12/10 07:47 AM Good to see mate is there any racing on over xmas im going to sydney on thrusday till the 10th Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/6/#findComment-1065429 Share on other sites More sharing options...
Phoontastic Donating Members 262 Member For: 19y 3m 27d Gender: Male Location: Canberra Posted 21/12/10 11:19 AM Share Posted 21/12/10 11:19 AM Dario, I'm very interested to see how you go playing around with the cam timing. I assume you're using the Atomic cam gears. Are you also going to try putting the factory cam gears back in so you get the variable phasing working again with the Stage 4s?? I'm wondering if these are why the factory cams work so well, and if they are, I'd expect even better things from the Stage 4s with them. Keep us posted. Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/6/#findComment-1065499 Share on other sites More sharing options...
6BOOST Gold Donating Members 139 Member For: 17y 4m 7d Gender: Male Posted 21/12/10 12:50 PM Share Posted 21/12/10 12:50 PM Are you not happy with the power increase of the stage 4 cams or the general running of them? If Jim hasn't tuned a car with cams before, the first time can take a bit of work to get your head around it, but when he gets it worked out they run just like stockers. Trust me, the stage 4's have absolutely NOTHING on how difficult the stage 5 cams are to tune 6BOOST Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/6/#findComment-1065548 Share on other sites More sharing options...
darios typhoon Member 73 Member For: 15y 11m 29d Gender: Male Location: northern beaches Posted 22/12/10 06:21 AM Author Share Posted 22/12/10 06:21 AM On 21/12/2010 at 11:19 AM, Phoontastic said: Dario, I'm very interested to see how you go playing around with the cam timing. I assume you're using the Atomic cam gears. Are you also going to try putting the factory cam gears back in so you get the variable phasing working again with the Stage 4s?? I'm wondering if these are why the factory cams work so well, and if they are, I'd expect even better things from the Stage 4s with them. Keep us posted.no im not putting the vct gears back on yet. im changing the cam timing from zero and seeing what works best as zero cam timing drops off to early 6000 rpm same as stock which is not right so soon will see if they dont do much the stock cams go back in with the atomic cam gears and if the cam gears dont work with the stock cams then the vct cam gears go back on as it was when it was stock Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/6/#findComment-1065743 Share on other sites More sharing options...
darios typhoon Member 73 Member For: 15y 11m 29d Gender: Male Location: northern beaches Posted 22/12/10 06:46 AM Author Share Posted 22/12/10 06:46 AM On 21/12/2010 at 7:47 AM, tray_182005 said: Good to see mate is there any racing on over xmas im going to sydney on thrusday till the 10thmay be have to get suspension sorted first early jan front runners and front brakes and buy some slicks for the 15 inch rims then tune on e90 also have to get the true trac diff as mine will break and put me in the wall { no !} Link to comment https://www.fordxr6turbo.com/forum/topic/68475-600kw-stock-internals/page/6/#findComment-1065761 Share on other sites More sharing options...
