Jimmyone Member 32 Member For: 16y 7m 14d Gender: Male Location: 742 Evergreen Terrace Posted 29/05/10 09:04 AM Share Posted 29/05/10 09:04 AM Hi Guys I just finished putting a new clutch in my ba xr6t series 2 and now I cant get it in gear. Had it in gear when I first started (with new clutch in)it then put it in neutral and now it won't go back. Makes a hi pitched squeak almost a whistle when I try.Anyone got some knowledge they want to throw my way? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 10d Gender: Male Location: @ my laptop Posted 29/05/10 09:45 AM Share Posted 29/05/10 09:45 AM Does the clutch pedal feel normal or really soft?Does it go into gear with the engine turned off? Link to comment Share on other sites More sharing options...
Jimmyone Member 32 Member For: 16y 7m 14d Gender: Male Location: 742 Evergreen Terrace Posted 29/05/10 10:46 AM Author Share Posted 29/05/10 10:46 AM The clutch feels pretty close to normal and it sh*ts through the gears with the engine off easily. Link to comment Share on other sites More sharing options...
Jimmyone Member 32 Member For: 16y 7m 14d Gender: Male Location: 742 Evergreen Terrace Posted 29/05/10 11:53 AM Author Share Posted 29/05/10 11:53 AM that would be Shifts. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 1m 2d Gender: Male Location: SW Sydney Posted 29/05/10 12:25 PM Share Posted 29/05/10 12:25 PM Was the clutch bled up completely? If you didn't have a friend to help you this may not have been done right, always remember that you can't let the clutch reservoir get empty otherwise it will just suck more air into the lines... Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 10d Gender: Male Location: @ my laptop Posted 29/05/10 11:24 PM Share Posted 29/05/10 11:24 PM Senna_T is correct, assuming the clutch has been fitted correctlty and the crush height is correct and it selects gears while the motor is off, the only other thing that can be a cause is the hydraulics, if all has been bled correctly and a new csc was used the only other thing that can be a problem ia the master cylinder. master cylinders are not normally a problem in these cars so we'll assume it is a bleeding issue. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 14d Gender: Male Location: Perth Posted 29/05/10 11:37 PM Share Posted 29/05/10 11:37 PM Did you fit the box up and push it home by hand or did you pull it up with the bolts? Link to comment Share on other sites More sharing options...
Jimmyone Member 32 Member For: 16y 7m 14d Gender: Male Location: 742 Evergreen Terrace Posted 30/05/10 02:54 AM Author Share Posted 30/05/10 02:54 AM Bleed the clutch well unless bubbles have a tendency to get stuck I would think that they are out.Pulled it home with the bolts probably the last cm or two Link to comment Share on other sites More sharing options...
OED666 Member 129 Member For: 18y 8m 13d Gender: Male Location: Gold Coast, Qld Posted 31/05/10 06:32 AM Share Posted 31/05/10 06:32 AM (edited) What clutch did you end up fitting? Is the clutch plate around the correct way (I know a stupid question, but I have seen it before). Edited 31/05/10 06:38 AM by RHR No need to quote above post. USE FAST REPLY Link to comment Share on other sites More sharing options...
Jimmyone Member 32 Member For: 16y 7m 14d Gender: Male Location: 742 Evergreen Terrace Posted 31/05/10 07:27 AM Author Share Posted 31/05/10 07:27 AM It is an Exedy. It could only be fitted one way the spring mechanism sticks out an inch or so on one side.Bleed it again full presser in the pedal now, no difference however. Link to comment Share on other sites More sharing options...
