  • Member For: 17y 9m 17d
I'm using a Bullseye Power S380R for my big banger. As Pat mentioned, they are rather large. The compressor housing is 10.5 inches across although it is rated to 1350hp so I don't mind so much. Snort looked after manifolds and it just squeezes in.
  • Member For: 16y 2m 12d
what's to stop you taking our GT35 and fitting ETT wheels and housings?
Nothing. That’s kind of what the Billet ETT turbos are.
The problem is the rpm the GT Ball Bearing turbines and the BorgWarner ETT compressors work at. The ETT compressor wheels generally operate at much lower shaft speeds so can be easily mismatched if you are only looking at compressor efficiency not being conscious of the shaft speed they operate at.
