Paulie2256 Donating Members 7,441 Member For: 16y 7m 13d Gender: Male Location: SE Melbourne Posted 01/06/10 01:05 AM Share Posted 01/06/10 01:05 AM Thanks for the tips champ.Also, what are your thoughts on genuine zf oil? is it worth it? Link to comment https://www.fordxr6turbo.com/forum/topic/68428-beefing-up-the-zf/page/2/#findComment-1012362 Share on other sites More sharing options...
djkice Boost Addict Member 1,273 Member For: 16y 11m 13d Gender: Male Location: Perth, W.A. Posted 01/06/10 01:20 AM Share Posted 01/06/10 01:20 AM genuine oil is for people who want warranty intact... Link to comment https://www.fordxr6turbo.com/forum/topic/68428-beefing-up-the-zf/page/2/#findComment-1012371 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 7m 27d Location: In The Ute Posted 01/06/10 01:32 AM Share Posted 01/06/10 01:32 AM Also, what are your thoughts on genuine zf oil? is it worth it?Used it for the first 3 or 4 transmissions years ago and had nothing but trouble with HP above STD so I went to Castrol TransmaxZ and have not a had a problem since. Link to comment https://www.fordxr6turbo.com/forum/topic/68428-beefing-up-the-zf/page/2/#findComment-1012376 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 11d Gender: Male Location: Probably above atmospheric pressure Posted 01/06/10 01:45 AM Share Posted 01/06/10 01:45 AM that's a noteworthy endorsement then!Do they really need to be filled using a complicated procedure? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/68428-beefing-up-the-zf/page/2/#findComment-1012379 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 7m 27d Location: In The Ute Posted 01/06/10 03:39 AM Share Posted 01/06/10 03:39 AM Not sure its complicated as such.Basically check with engine running and fill to the bottom of the fill hole in the r/h rear side.Just above Pan level.So another words fill till its running out the same hole your filling from with the engine running and then make sure you put the filler Plug back in whilst the engine is still running... Drive it and recheck (with engine Running) once its settled down and warm and the air has bled out. Link to comment https://www.fordxr6turbo.com/forum/topic/68428-beefing-up-the-zf/page/2/#findComment-1012397 Share on other sites More sharing options...
winter bft Member 56 Member For: 17y 9d Gender: Male Location: melbourne Posted 01/06/10 05:03 AM Author Share Posted 01/06/10 05:03 AM thank you so much for your help F6_Tornado. I got a quote around the $2500 mark and that's if I take out the trany, let them fit clutch packs, and for me to put the box back in. does that sound a little pricey? Link to comment https://www.fordxr6turbo.com/forum/topic/68428-beefing-up-the-zf/page/2/#findComment-1012418 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 7m 27d Location: In The Ute Posted 01/06/10 05:56 AM Share Posted 01/06/10 05:56 AM I guess that depends on what they are putting in it! however to me that sounds high as you are removing and fitting and as such will be paying for the oil, labor etc so all they will be doing is modifying a couple of clutch packs and depending on what Input shaft is in it now maybe a new Shaft. U need to know what they are changing. It would have to be absolutely U/S to cost that much and maybe they are quoting a worst case?However they may quote worst case and if its in good nick then they make a killing but if its rooted they only make 30% profit. A steel Pan with a Drain and changeable filter is @ $300. but next service all u need to buy is a Filter.The weak point are E and B clutches and they both need to be beefed up along with the input shaft if its the older type. it doesn't hurt to do A,C & D packs whilst in there.But you can only go so far as the Intermediate shaft along with the input will only take so much HP so there is a limit to what you can do and as such a limit to what you can spend on one.Like I said before U need to know what they are changing.Or what they are telling you they are changing. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/68428-beefing-up-the-zf/page/2/#findComment-1012428 Share on other sites More sharing options...
winter bft Member 56 Member For: 17y 9d Gender: Male Location: melbourne Posted 01/06/10 06:53 AM Author Share Posted 01/06/10 06:53 AM well the box has never missed a beat, doesn't slip and changes gears perfectly. I just want to beef it up before I eff it up. they told me they add a few clutch packs and change the input shaft to an FG one. the steel pan and oil I will be supplying. where can I buy clutch packs and the input shaft from? Link to comment https://www.fordxr6turbo.com/forum/topic/68428-beefing-up-the-zf/page/2/#findComment-1012445 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 7m 27d Location: In The Ute Posted 01/06/10 07:26 AM Share Posted 01/06/10 07:26 AM Farkkkkk Input shaft is only @ $500.00 including a BIG mark up (I pay much less) so that leaves $2k for a handful of plates and discs with some piston machine work @ $100. Couple of hours labor!! Id be shopping around if I was you.Maybe ask some of the guys who have had them done and see what they have paid? and ask by Whom. Link to comment https://www.fordxr6turbo.com/forum/topic/68428-beefing-up-the-zf/page/2/#findComment-1012456 Share on other sites More sharing options...
winter bft Member 56 Member For: 17y 9d Gender: Male Location: melbourne Posted 01/06/10 07:39 AM Author Share Posted 01/06/10 07:39 AM (edited) thank you so much for your help. your a gun. I would've got ripped-off if it wasn't for this forum. thanks heaps again. also is there anyone/anywhere you can recommend for me to buy the parts that I will need? Edited 01/06/10 07:41 AM by winter bft Link to comment https://www.fordxr6turbo.com/forum/topic/68428-beefing-up-the-zf/page/2/#findComment-1012461 Share on other sites More sharing options...
