  • Member For: 16y 11m 26d
hi guys had a bit of a look in search but couldnt find anything on this. Just wondering if anyone else has had there power window get stuck when winding up. mine gets stuck in two spots about halfway up and then again a little bit further up if you help the motor by pulling the window up past these points it continues going. Could this be the motor on the way out or is there a problem with the trim. its a BA by the way.
https://www.fordxr6turbo.com/forum/topic/68362-stuck-window/
  • Member For: 16y 5m 11d
Take all the rubber out, pull the window out or rest on a bit of cloth (so it doesnt get scratched on the door) take the 2 furry thingy watsits out and clean them. (be carefull not to bend them though).
Then put everything back in. It looks hard but actually extremely easy to do. It should fix the issue.
