Jmpin Member 111 Member For: 17y 7m 1d Gender: Male Location: South Coast NSW Posted 21/05/10 04:58 AM Share Posted 21/05/10 04:58 AM Hi guys,just wanted to know if anyone else has had heater problems with there BAs or BFs?I have a BA turbo and the other day I went to turn the de mister on only to find out I had no hot air.I checked the heater hoses running into the firewall, both where hot... indicating to me no blockage.I have been told there is a plastic linking rod of some sort that moves the flap from cold to open and that this could be broken, has anyone had this or a similar problem with a different fix?any help would be great.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/68292-heater-not-working-help/ Share on other sites More sharing options...
FR33DY Member 307 Member For: 20y 2m 7d Gender: Male Location: Sydney Posted 21/05/10 06:57 AM Share Posted 21/05/10 06:57 AM On 21/05/2010 at 4:58 AM, Jmpin said: Hi guys,just wanted to know if anyone else has had heater problems with there BAs or BFs?I have a BA turbo and the other day I went to turn the de mister on only to find out I had no hot air.I checked the heater hoses running into the firewall, both where hot... indicating to me no blockage.I have been told there is a plastic linking rod of some sort that moves the flap from cold to open and that this could be broken, has anyone had this or a similar problem with a different fix?any help would be great.CheersI had this issue a few years back, you need to take it to ford to be fixed, its a big job as they need to pull out the dash and replace the control arm. I was charged $600. Link to comment https://www.fordxr6turbo.com/forum/topic/68292-heater-not-working-help/#findComment-1009526 Share on other sites More sharing options...
mercuryturbo Oh look.... a real car, with no hair dryer Donating Members 1,724 Member For: 18y 8m 21d Gender: Male Location: Fear and Loathing in Callala Bay Posted 21/05/10 07:51 AM Share Posted 21/05/10 07:51 AM There's a couple of threads on here devoted to this but yes the mixer shaft is probably stripped.With the car parked in quiet place turn the heater dial to hot, if you can hear a faint whirring sound then the mixer shaft is cactus, if you dont hear the whirring then its most likely the HIM module.Either way its a dash-out job. Link to comment https://www.fordxr6turbo.com/forum/topic/68292-heater-not-working-help/#findComment-1009550 Share on other sites More sharing options...
ColinT Donating Members 372 Member For: 20y 3m Posted 22/05/10 06:05 PM Share Posted 22/05/10 06:05 PM Had exactly the same happen recently.As was said the dash has to come out and the control arm shaft replaced.It should have cost me $650 to have this done but as the car was 2 days out of its extended Ford warranty and I complained to Ford I only paid $325. Link to comment https://www.fordxr6turbo.com/forum/topic/68292-heater-not-working-help/#findComment-1009849 Share on other sites More sharing options...
dooka Member 7 Member For: 14y 1m 26d Posted 15/04/11 09:19 AM Share Posted 15/04/11 09:19 AM my air con aand heater are working but the fan has stopped all fuses are good any ideas Link to comment https://www.fordxr6turbo.com/forum/topic/68292-heater-not-working-help/#findComment-1097129 Share on other sites More sharing options...
