icer Banned 2,335 Member For: 15y 10m 7d Gender: Male Location: Aspendale, Vic. Posted 21/05/10 10:01 AM Share Posted 21/05/10 10:01 AM winter bft: bayswater auto's. Talk to Phil there. Link to comment https://www.fordxr6turbo.com/forum/topic/68275-6spd-zf-busted-what-now/page/4/#findComment-1009587 Share on other sites More sharing options...
tonyv EPC Member Donating Members 1,598 Member For: 16y 5m 21d Gender: Male Posted 21/05/10 10:41 AM Author Share Posted 21/05/10 10:41 AM same guy who done all my work. I think I hurt it before the service though. that's when I was getting the symptoms, so I decided to service it to see if that was the problem Link to comment https://www.fordxr6turbo.com/forum/topic/68275-6spd-zf-busted-what-now/page/4/#findComment-1009589 Share on other sites More sharing options...
Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 19y 1m 12d Gender: Male Location: Bentleigh, Vic, Australia Posted 23/05/10 02:18 PM Share Posted 23/05/10 02:18 PM On 21/05/2010 at 6:04 AM, R-SPEC said: They just replace the input shaft and the clutch packs for 1st 3rd and 6th dont they?Funny you say that actually...I find the changes from 1-2 and 3-4 are the ones that tend to slip. Yet the change from 2-3 seems to be fine... Link to comment https://www.fordxr6turbo.com/forum/topic/68275-6spd-zf-busted-what-now/page/4/#findComment-1010072 Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 19y 11m 4d Location: Canberra Posted 23/05/10 10:56 PM Share Posted 23/05/10 10:56 PM Sorry for the thread hijack! But I recently bought a turbo terry, and sometimes when I change from 2-3 or 3-4 the revs still sit at about 3000rpm for a bit (not belting it, just normal driving). Or the other day I was overtaking in normal D mode and when I backed off the accelerator the revs were still high and slowly coming down (it didn't change into 5th or 6th) and I had to manually shift it to 6th to get the revs back. Is this normal?? I only bought it 3wks ago, and plan to take it to CV for a tune and injectors soon... But if it's got a gearbox issue I'd rather let ford sort it out first. It's only got 32,000kms on it (07 model). Link to comment https://www.fordxr6turbo.com/forum/topic/68275-6spd-zf-busted-what-now/page/4/#findComment-1010105 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 6m 16d Gender: Male Location: Perth, NOR Posted 24/05/10 12:07 AM Share Posted 24/05/10 12:07 AM IF you are on the gas a bit, and you suddenly back off it, the gearbox will hold that gear till you either tap/apply the brakes or keen on driving fast a bit longer.Not sure if that's similar to the second example you said about the revs still being high and going down slowly. Link to comment https://www.fordxr6turbo.com/forum/topic/68275-6spd-zf-busted-what-now/page/4/#findComment-1010115 Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 17y 8d Gender: Male Location: adelaide hills- 'race air' central Posted 24/05/10 12:09 AM Share Posted 24/05/10 12:09 AM I reckon 300rwkw was a bit conservative with 12.2 et's? Link to comment https://www.fordxr6turbo.com/forum/topic/68275-6spd-zf-busted-what-now/page/4/#findComment-1010116 Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 19y 11m 4d Location: Canberra Posted 24/05/10 12:26 AM Share Posted 24/05/10 12:26 AM On 24/05/2010 at 12:07 AM, XF Falcon said: IF you are on the gas a bit, and you suddenly back off it, the gearbox will hold that gear till you either tap/apply the brakes or keen on driving fast a bit longer.Not sure if that's similar to the second example you said about the revs still being high and going down slowly.Oh ok, cool thanks mate! Link to comment https://www.fordxr6turbo.com/forum/topic/68275-6spd-zf-busted-what-now/page/4/#findComment-1010121 Share on other sites More sharing options...
rockafellqeinstien Member 325 Member For: 16y 10m 1d Posted 24/05/10 12:48 AM Share Posted 24/05/10 12:48 AM Just remember it is not KW that kills g,boxes (or difs) its the torque.Power (kW) = Torque (N.m) x Speed (RPM) / 9.5488 Based of your figures of 300rwkw and 1100nm (asume r/w also) you would be making 300rwkw (and 1100nm)at 2577rpm which is f'ing huge. For comparison, I have 300rwkw also but at 4100rpm and my torque at that rpm is 716NM.A flat torque courve (table) of about 800NM through to 5250 will give a maximum of 450rwkw at 5250 which would be pretty nice.remember 300kw at 2000rpm is just as fast as 300kw at 5000rpm (just you have make 1430NM at 2000rpm vs 572 @ 5000rpm). You just wont have that huge rush when in 5th or 6th down low.that's my science leson for the day Link to comment https://www.fordxr6turbo.com/forum/topic/68275-6spd-zf-busted-what-now/page/4/#findComment-1010132 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m Gender: Male Location: Probably above atmospheric pressure Posted 24/05/10 04:36 AM Share Posted 24/05/10 04:36 AM Aren't 5th and 6th overdrive or something? And that means bad to apply much power to? I'd cruise only in 5th or 6th and drop to 3rd or so for overtaking on the open road if my theory is correct. Link to comment https://www.fordxr6turbo.com/forum/topic/68275-6spd-zf-busted-what-now/page/4/#findComment-1010191 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 6m 16d Gender: Male Location: Perth, NOR Posted 24/05/10 04:48 AM Share Posted 24/05/10 04:48 AM Yeah 5th and 6th are overdrive gears And 4th is the gear to use on dyno's as its the closest to 1:1 gearing.1 - 4.17:12 - 2.34:13 - 1.52:14 - 1.14:15 - 0.87:16 - 0.69:1 Link to comment https://www.fordxr6turbo.com/forum/topic/68275-6spd-zf-busted-what-now/page/4/#findComment-1010196 Share on other sites More sharing options...
