EnricoPalazzo Member 84 Member For: 19y 9m 21d Posted 18/05/10 01:09 PM Share Posted 18/05/10 01:09 PM (edited) Hi Guys,I have an issue with my Fg F6 (ZF).Basically if I turn TC OFF, I still get power cuts, which feel like traction control kicking in.I also noticed when I have it in Performance mode, If the power cuts occurs, the Centre Display ppops up with "performance mode" and then goes back to the speedi.Has anyone experienced any issues like this. It is extrememely annoying and the car is not very enjoyable to drive hard due to this. I also feel it is down in power, could fouled spark plugs be causing this problem?Thanks in advance.. Edited 18/05/10 01:10 PM by EnricoPalazzo Link to comment https://www.fordxr6turbo.com/forum/topic/68215-power-cut-but-traction-control-off/ Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 10m 16d Gender: Male Location: Victoria Posted 18/05/10 07:50 PM Share Posted 18/05/10 07:50 PM Yeah... Maybe a spark plug or a coil. How many kms??? Dunno about the dash thing with performance mode... Is the dash showing TC off properly? Link to comment https://www.fordxr6turbo.com/forum/topic/68215-power-cut-but-traction-control-off/#findComment-1008766 Share on other sites More sharing options...
BensXR6T Member 478 Member For: 16y 5m 2d Gender: Male Location: Burpengary QLD Posted 18/05/10 09:57 PM Share Posted 18/05/10 09:57 PM (edited) Has the car been tuned or is it still stock?Does it happen at the same RPM?If it's been tuned and happens at the same rpm every time, could be a torque tag setting somewhere.If it's still stock, then coils and/or plugs would cause it.Take it down to a workshop and ask them to plug a scan tool in and look for codes. Edited 18/05/10 09:57 PM by BensXR6T Link to comment https://www.fordxr6turbo.com/forum/topic/68215-power-cut-but-traction-control-off/#findComment-1008776 Share on other sites More sharing options...
EnricoPalazzo Member 84 Member For: 19y 9m 21d Posted 19/05/10 08:51 AM Author Share Posted 19/05/10 08:51 AM Hi guys, car is tuned, I havent noticed if its at the same rpm, I will be more aware of revs of when it happens. TC is definately off, as light is illuminated on dash.So sounds like tourqe tag from tranny? Link to comment https://www.fordxr6turbo.com/forum/topic/68215-power-cut-but-traction-control-off/#findComment-1008933 Share on other sites More sharing options...
