TUR-BO6 There's a thin line between a wild time and a flat line. Member 146 Member For: 16y 4m 12d Gender: Male Location: Vic Nsw border. Posted 18/05/10 01:00 PM Share Posted 18/05/10 01:00 PM Just thought we could get a few points of view on periodic maintenance for these toys.Also if anyone has the Service Schedule for them too.Maybe note in the top corner the vehicle you are referring to when you post a maintenance item for example so fpv differences or what not can be deciphered.We've seen thus far:10k intervals to WD40 your wastegate solenoid.50k " " change fuel filter.5k oil and filter (if your pedantic on servicing.)100k Coils.Please make adjustments or additions guys... Hope this makes maintenance easier for everyone... Enjoy! Link to comment https://www.fordxr6turbo.com/forum/topic/68214-service-schedule/ Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 17d Gender: Male Location: Probably above atmospheric pressure Posted 18/05/10 01:46 PM Share Posted 18/05/10 01:46 PM 10k intervals to WD40 your wastegate solenoid and clean out throttle body!50k " " change fuel filter.5k oil and filter (if your pedantic on servicing.)100k Coils. Link to comment https://www.fordxr6turbo.com/forum/topic/68214-service-schedule/#findComment-1008741 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 22d Gender: Male Location: Earth Posted 18/05/10 05:03 PM Share Posted 18/05/10 05:03 PM (edited) Diff oil 20-50K depending on your driving style.Clutch fluid 10-20KGearbox oil 50K (manual)Coolant 50KAirfilter (If K&N) clean and relube every 5KRotate tyres 5KSteering oil 20-50KIt's what I have and will be doing to my FG.Inlet manifold bolts 10KClean intake pipework 10KBrake fluid 50K or 2 years. Edited 18/05/10 05:05 PM by PHANTMXR6 Link to comment https://www.fordxr6turbo.com/forum/topic/68214-service-schedule/#findComment-1008761 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 20d Gender: Male Location: SE Melbourne Posted 18/05/10 11:32 PM Share Posted 18/05/10 11:32 PM 5-10k oil and filter 10k-WD40 your wastegate solenoid 10k-tighten manifold and turbo bolts10k-squirt of subaru TB cleaner10-20k clutch fluid50k-manual gearbox oil50k-change fuel filter.50k-diff oil50-80k Coolant50-100k Power steering fluid50-100k Brake fluid80k-plugs80k-air filter (regular cleaning)100k-Coils. 100-160K ZF oil and filter if genuine oil used. (Not sure how often you guys with aftermarket oil are changing. 50k?)I may have been a bit generous with the km's. I know some will argue saying they change all this everytime their car leaves the driveway. Link to comment https://www.fordxr6turbo.com/forum/topic/68214-service-schedule/#findComment-1008789 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 22d Gender: Male Location: Earth Posted 18/05/10 11:38 PM Share Posted 18/05/10 11:38 PM One of the most important things that I forgot, if you still have it fitted, is the turbo oil supply screen.It should be cleaned every oil change. Link to comment https://www.fordxr6turbo.com/forum/topic/68214-service-schedule/#findComment-1008791 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 20d Gender: Male Location: SE Melbourne Posted 18/05/10 11:50 PM Share Posted 18/05/10 11:50 PM Excellent point. Didn't think of it either cause I got rid of the whole line a long time ago. Link to comment https://www.fordxr6turbo.com/forum/topic/68214-service-schedule/#findComment-1008793 Share on other sites More sharing options...
TUR-BO6 There's a thin line between a wild time and a flat line. Member 146 Member For: 16y 4m 12d Gender: Male Location: Vic Nsw border. Posted 20/05/10 12:30 PM Author Share Posted 20/05/10 12:30 PM On 18/05/2010 at 11:38 PM, PHANTMXR6 said: One of the most important things that I forgot, if you still have it fitted, is the turbo oil supply screen.It should be cleaned every oil change.that being...? for the uneducated... Link to comment https://www.fordxr6turbo.com/forum/topic/68214-service-schedule/#findComment-1009304 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 22d Gender: Male Location: Earth Posted 20/05/10 12:39 PM Share Posted 20/05/10 12:39 PM If not inspected and cleaned it can become blocked over time, causing oil starvation to the turbo bearings. If that happens bye bye turbo bearing cartridge, hello expensive repairs.Very important to at least check it. Link to comment https://www.fordxr6turbo.com/forum/topic/68214-service-schedule/#findComment-1009314 Share on other sites More sharing options...
TUR-BO6 There's a thin line between a wild time and a flat line. Member 146 Member For: 16y 4m 12d Gender: Male Location: Vic Nsw border. Posted 20/05/10 12:57 PM Author Share Posted 20/05/10 12:57 PM (edited) ???what is it though???is that the pipe from the oil supply that goes over the exhaust manifold? Edited 20/05/10 12:57 PM by TUR-BO6 Link to comment https://www.fordxr6turbo.com/forum/topic/68214-service-schedule/#findComment-1009320 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 22d Gender: Male Location: Earth Posted 20/05/10 01:42 PM Share Posted 20/05/10 01:42 PM The screen is fitted in the oil supply pipe to the turbo yes.It is located on the side of the block below the inlet manifold.To get it out you need to remove the sender unit from the fitting that comes out of the block and then remove the nut on top of the oil pipe. You can clean it out with contact cleaner or carby cleaner and refit it. Have a read about it in here.http://www.fordxr6turbo.com/forum/index.php?showtopic=32461Some say remove it, some say keep it. I will be keeping mine as I know the history of my car and it serves a purpose. Link to comment https://www.fordxr6turbo.com/forum/topic/68214-service-schedule/#findComment-1009333 Share on other sites More sharing options...
