xrsixturbo Member 3 Member For: 14y 11m 27d Posted 17/05/10 11:09 PM Share Posted 17/05/10 11:09 PM Hey Guys I have an ex Federal Police 2003 BA xr6 turbo Stock. It has been pretty good so far but now it has about 185,000 km. Over the last few weeks I have realised than when I rev it out ( beyond 3000 rpm ) it refuses to boost and the engine sounds like a "farting machine gun" ( almost similar to what happens when tractions control is going off - even though its not on ) I noticed this a few weeks ago - and only happened once in a blue moon but now it is happening more and more often.Any idea what it could be? possible my turbo on it way out? or just something loose / loosing boost pressure somewhere? Also it has been making a blowoff valvue noise for a while ( last 9 months or so ) even though I didn't fit it with any after marker BOV ( guys at ford say it was over boosting ) Link to comment https://www.fordxr6turbo.com/forum/topic/68194-engine-loosing-a-lot-of-power-turbo-failing/ Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 8m 10d Gender: Male Location: Southern Highlands NSW Posted 18/05/10 12:14 AM Share Posted 18/05/10 12:14 AM Coils/plugs could also be valve springs Link to comment https://www.fordxr6turbo.com/forum/topic/68194-engine-loosing-a-lot-of-power-turbo-failing/#findComment-1008507 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 11m 25d Gender: Male Location: Sydney NSW Posted 18/05/10 12:40 AM Share Posted 18/05/10 12:40 AM Looks like time for a good service, change all the basics such as spark plugs, fuel & air filters, clean out the boost solenoid, clean the turbo feed oil line/change filter.Torque up all exhaust manifold bolts/studs, all the turbo bolts/studs. Tighten all hose clamps on the intercooler system & intake.With all the basic service things done, if theres still issues you/workshop can start looking at bigger areas such as coils, turbo ect.But allways smart to sort all the basics out first, especially at these high kays. Link to comment https://www.fordxr6turbo.com/forum/topic/68194-engine-loosing-a-lot-of-power-turbo-failing/#findComment-1008514 Share on other sites More sharing options...
xrsixturbo Member 3 Member For: 14y 11m 27d Posted 18/05/10 01:11 AM Author Share Posted 18/05/10 01:11 AM (edited) Thanx guy - yeah just had a $500- ford server about 6 weeks ago or so ( roughly when I started noticing the problem ) - so either they didn't do it property or something worse is happening. - I've rebooked it for Friday fingers crossed Edited 18/05/10 01:24 AM by RHR No need to quote above post. USE FAST REPLY Link to comment https://www.fordxr6turbo.com/forum/topic/68194-engine-loosing-a-lot-of-power-turbo-failing/#findComment-1008520 Share on other sites More sharing options...
Benji_vs Donating Members 403 Member For: 17y 8d Gender: Male Location: East Suburbs Melbourne Posted 18/05/10 02:34 AM Share Posted 18/05/10 02:34 AM No doubt coils or plugs, seems to happen alot with these cars. Let us know the verdict. Link to comment https://www.fordxr6turbo.com/forum/topic/68194-engine-loosing-a-lot-of-power-turbo-failing/#findComment-1008531 Share on other sites More sharing options...
nimsie Member 45 Member For: 18y 8m 13d Gender: Male Posted 18/05/10 03:50 AM Share Posted 18/05/10 03:50 AM Try your fuel pump. Mine was doing the same. It would get to 3000 rpm and shudder. After changing my plugs and fuel filter I started to think about coils. After I took it to Blacktrack (Justin) he told me my fuel pump wasn't giving enough pressure. It was fine for normal driving, but it struggled under high boost.Now it doesn't miss a beat. Link to comment https://www.fordxr6turbo.com/forum/topic/68194-engine-loosing-a-lot-of-power-turbo-failing/#findComment-1008553 Share on other sites More sharing options...
xrsixturbo Member 3 Member For: 14y 11m 27d Posted 18/05/10 05:17 AM Author Share Posted 18/05/10 05:17 AM that sound's like good news at least its not the turbo about to fail - yeah shudder is exactly what happens in these case scenarios what should I expect to to fork out to fix / replace : Coils/plugs or fuel filter Link to comment https://www.fordxr6turbo.com/forum/topic/68194-engine-loosing-a-lot-of-power-turbo-failing/#findComment-1008570 Share on other sites More sharing options...
xr6turboman Donating Members 588 Member For: 17y 1m 2d Gender: Male Location: New Zealand, Palmerston North Posted 18/05/10 10:07 AM Share Posted 18/05/10 10:07 AM My money is on coils.. mine was doing exactly the same thing I got coils at $120 Eac in NZ though so it will no doubt be cheaper for you Link to comment https://www.fordxr6turbo.com/forum/topic/68194-engine-loosing-a-lot-of-power-turbo-failing/#findComment-1008663 Share on other sites More sharing options...
