  • Member For: 20y 11m 25d
hey Kyle con grats on the times and dyno runs, mine is 3.46, runing 6500 across the line,at 148mph, but mine is 1600kg's and only making 800rhp, so things are not even, and if it coasted across the line that will make up for it anyway,
David
  • Replies 67
Posted Images
  • Member For: 17y 3m 28d
  On 22/05/2010 at 9:45 PM, yeahyo said:
why was this packed up so early at powerplay. underbonnet look's insane.
Because 1100hp and C4's don't play well together, broken input shaft :w00t2: Easy fixed and will be back out again soon.
6BOOST
  • Member For: 20y 1m 14d
I was actually kind of impressed it lasted this long Kyle, with the amount of mumbo the FG is making, T400 or Glide on the cards?
As far as the cage goes, I'm not sure what Braydens plan is. I know he wants to take it out again before, but I'm not overly keen on pulling up from 150mph with no chute and stock brakes in a 1900kg car/driver, and the safety aspect of that sort of car and speed with no cage
6BOOST
Not many people take this into consideration surprisingly enough (well explained Kyle).............. :spoton::blink::w00t2:
  • Team Xtreme
  • Member For: 20y 3m 13d
Not only does that car look bloody great it goes very vey hard. Well done 6boost and to all involved in the car. :buttrock:
Man FG's just look so damn :turboboink:
At this stage Spiro the C4 will stay, the box itself is holding up ok, we had the pan off after the dyno day and the oil was good, no burnt smell or look, and th eband only needed minimal adjustment. No doubt it will need a Glide at some stage, but I'd say that will be a while away. We'll fix it, race it, then do the cage and 9" conversion, if it doesn't hold up we'll then look into the glide :turboboink:
  • Team Xtreme
Kyle does any one do a glide bell housing for our 6 or do they just use a adaptor plate?
Dellow does a bell housing, but they aren't very nice, someone just got a stock bell, welded the adapter on, cast it poorly, and sold it. I would use a stock bell with adapter before using another one of those, you can even see the weld marks from where the adapter was welded in before casting :turboboink:
6BOOST
