Pete A Member 442 Member For: 16y 7m 2d Gender: Male Location: Castle Hill NSW Posted 15/05/10 10:44 AM Share Posted 15/05/10 10:44 AM Hi Guys,FG 6T. Yesterday the DSC and ABS fault messages came up in the menu display. Stopping the engine and starting it again the error goes away for a while but comes back some time later. Car seems to go and stop OK. Anyone had this before? The car is going in to get something else fixed in a week so I'll get them to check it. Doesn't seem the adversley affect the car. Anyone had this problem? Any concern about driving the car in the meantime? It seems quite normal. Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/68150-dsc-and-abs-fault/ Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 5m 5d Posted 15/05/10 12:26 PM Share Posted 15/05/10 12:26 PM I dare say you might have a problem with your brake pedal switches. Have had a few through with the same concern and ended up being the problem. Things like abs sensors can do the same thing but havent had any dramas with them yet in the FGs. Your abs and stability control wont work when the lights are on but is still ok to drive carefully. Link to comment https://www.fordxr6turbo.com/forum/topic/68150-dsc-and-abs-fault/#findComment-1007899 Share on other sites More sharing options...
Pete A Member 442 Member For: 16y 7m 2d Gender: Male Location: Castle Hill NSW Posted 26/05/10 10:01 AM Author Share Posted 26/05/10 10:01 AM That' what it was. The brake pedal switches. All fixed! thanks Link to comment https://www.fordxr6turbo.com/forum/topic/68150-dsc-and-abs-fault/#findComment-1010867 Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 20y 1m 17d Posted 26/05/10 11:35 PM Share Posted 26/05/10 11:35 PM I get the DSC light go on and have had this fixed by Ford under warranty but it still keeps comming back... mine tends to be a sensor in the front left steering area that keeps needing recalibration I think I was told if the wheel alignment goes out by a certain angle then it will trigger it...but this just triggers my DSC...not my ABS... Link to comment https://www.fordxr6turbo.com/forum/topic/68150-dsc-and-abs-fault/#findComment-1011039 Share on other sites More sharing options...
M>A<B Member 4 Member For: 14y 5m 13d Posted 23/01/11 04:07 AM Share Posted 23/01/11 04:07 AM I get the DSC light go on and have had this fixed by Ford under warranty but it still keeps comming back... mine tends to be a sensor in the front left steering area that keeps needing recalibration I think I was told if the wheel alignment goes out by a certain angle then it will trigger it...but this just triggers my DSC...not my ABS...hey I have a 03 ba xr6 turbo an I got simular problem, my abs and t/c light keeps coming on, an then I have no t/c Link to comment https://www.fordxr6turbo.com/forum/topic/68150-dsc-and-abs-fault/#findComment-1074856 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 28d Gender: Male Location: SW Sydney Posted 23/01/11 06:09 AM Share Posted 23/01/11 06:09 AM do any of you guys have different diameter wheels or tyres front to back? I had the abs and tc lights come on when I had a different tyre profile front to back Link to comment https://www.fordxr6turbo.com/forum/topic/68150-dsc-and-abs-fault/#findComment-1074886 Share on other sites More sharing options...
_John_ Member 287 Member For: 14y 8m 14d Gender: Male Posted 23/01/11 09:11 AM Share Posted 23/01/11 09:11 AM This is an awesome problem especially when the light comes on seemingly at random. You clean the sensors and it stays away and ooooh hooo hooo! I`ve fixed it then whack! light on you dirty *&^%er!If its not stagger wheel fitment like Pat says or even dirty sensors, someone with a scantool ( like a dealer ) can soon tell you what it is.Mine was a bad sensor on the passenger front. I imagined I`d stretched the wire on atleast one when I fitted new coils and turns out the one I started on and really, made all the mistakes on, was the pass. front.My tuner graciously gave me a couple of wheel sensors and after replacing that left front its been plain saling ever since.P.S. if you want a wild ride, really pounce on the anchors with the ABS deactivated. I did and was stunned at how untidy it all got. Link to comment https://www.fordxr6turbo.com/forum/topic/68150-dsc-and-abs-fault/#findComment-1074946 Share on other sites More sharing options...
M>A<B Member 4 Member For: 14y 5m 13d Posted 24/01/11 05:00 AM Share Posted 24/01/11 05:00 AM nah ive got pair of 18" mags from the BF falcon's on, its prity dam low but dont no if the guy who lowerd it f@cked the sensor..had prity wild ride in the wet on sat day, had to put the foot down to get out the way of this car an I ended up back wards between trafic islands,hahah Link to comment https://www.fordxr6turbo.com/forum/topic/68150-dsc-and-abs-fault/#findComment-1075135 Share on other sites More sharing options...
davr0s Member 2 Member For: 14y 5m 27d Posted 24/01/11 07:56 PM Share Posted 24/01/11 07:56 PM I've got a 2007 BF and when headlights are on the DSC / TC light illuminates. I also lose cruise control. Is this normal or fixable? dave Link to comment https://www.fordxr6turbo.com/forum/topic/68150-dsc-and-abs-fault/#findComment-1075301 Share on other sites More sharing options...
davr0s Member 2 Member For: 14y 5m 27d Posted 25/01/11 09:45 AM Share Posted 25/01/11 09:45 AM Contacted loacl Ford dealer about DSC and crusie control turning off when headlights are switched on. Initial diagnostic scan was $120 so thought I'd try a few things first. For $7 replacved rear stop and tail lights with the cheapies from Repco. Originally the LED type which someone mentioned before. Upon removal noticed they were a bit loose. New bulbs and evrything works great.! Link to comment https://www.fordxr6turbo.com/forum/topic/68150-dsc-and-abs-fault/#findComment-1075465 Share on other sites More sharing options...
