I'm Now Running 375hp At The Treads!
Guest 56Mainline
Guest 56Mainline
  • Guests
How much have the different mod's cost you so far??
What costs are involved with the chip?
What did the exede cost you ?
The following lists all my expenses to date for everything I've modified:
Sound Insulation Boot Floor - $52.99
Boot Lid Liner & Retaining Clips - $62.50
Rear Brake/indicator Lens Tinting - $14.95
Alloy Pedals (purchased on special 50% off) - $30.36
Intercooler Black Alloy Grille Mesh + 'XR6 Turbo' Badge - $85.00
Fog lamp replacement with Hella driving light/relay/clear protective covers/wire/etc - $99.15
replace centre muffler with straight s/s pipe - $120.00
Front & rear bumper bar Pinstriping, 6mm black - $4.00 (on special)
Boost Gauge/pressure line kit/T-piece/blue LED & resistor for backlighting - $68.44
XR8 underheadlight intake & ducting - $73.92
Blue condoms for wedge bulbs - $4.50
K&N Filter - $144.98
Chiptorque Xede Processor, Tuning, workshop supplies, etc - $1,718.20
Blue SMD LED Power Window Switches - $50.78
Total spent to date: $2,529.77 :D (I'm fairly anal retentive when it comes to record keeping expenses!!! :thumbsup: )
  • Replies 81
Posted Images
Guest 56Mainline
  • Guests
....the exede ....was it just there Stage 1 ?
Mmmmm yes, but figures quoted on internet etc are based on a stock car.
Do a few other mods and the Tuner can get different power figures.
what boost you are running?
8.1 to 8.4 psi at the manifold, depending on ambient conditions (air temp, barometric pressure, air density). See spikes to 9psi on occassion.
...chiptorqe.....who done it as I live in sydney?
Scotts Dyno-Tune in Mayfield (suburb of Newcastle, home of the mighty Knights!).
Chiptorque also has a dealer in Sydney suburb of Silverwater, details on their web page.
I'll bet you're grinning like the cat that ate the budgy.
:laughtcont:
  • Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car
  • Member For: 21y 6m 16d
The car and what you have done to it sound's fantastic without going over the top, would love to see a pic of the car, just like to know who fitted xede and thanks for the feed back :thumbsup:
Guest 56Mainline
  • Guests
good mods and good figures ... but I reckon you might be running on the edge... injectors/pump/zorst are really important for reliability and maintainability, without them at the level you are now is dicey for a prelonged period of time
I like to push the envelope...to the EDGE!!! B)
Nah, but really, I was told by the Tuner that the injectors are at their limits in this application. They believe all will be OK and within safe parameters even with more kms both on the fuel pump (pressure degrades over time/kms/age) and the injectors (dirty injectors therefore less fuel therefore lean mix).
Never the less, I did experience some fuel cut due to overboost caused by boost creep. We couldn't find the cause for this, some twiddling of the Xede to bring the boost back even further than original set as a safety margin.
Installed boost gauge is to monitor for boost creep again.
The air/fuel ratio set in the Xede (as set for my car) is set to reduce the factory settings by approx 10 to 20%, depending upon MAP, MAF and throttle position. These cars are running pretty rich!
A by-product of all this is not just the peak power, but my power & torque before boost and at low boost is up above standard. Additionally my cold idle speed is lower (not it's not so loud when I kick her in the guts in the mornings). Also, and it may be just me, but I swear the car is running smoother at idle, at pre-boost revs, and in just-on-throttle cruising.
The only downsides are that you need to wait a moment on start-up whilst the processor powers-up and is ready to start intercepting (a couple of seconds), and the car seems harder to start. It takes a bit more time with the starter motor going before the girl fires-up.
Guest 56Mainline
  • Guests
I'll get some pictures this evening of all that I think is relevant.
Be prepared for a dirty T, it's been 1.5 weeks since it's had a bath, it's currently drizzling on and off, and I am traveling to/from work on roads that are used to truck coal.....sometimes the duco ain't a pretty sight!
  • Site protagonist
  • Member For: 21y 7m 26d
Are there any Chiptorque workshops in Melbourne that you know of ? :thumbsup:
  • Member For: 22y 9d
56Mainline, sounds great, have been trying to weigh up APS and ChipTorque as well so this info is very good.
In your price list to date you mention
Is this a ford item or just some stuff from Clark rubber etc
Regards
Craig
