nelsonian101 Donating Members 961 Member For: 16y 8m 12d Gender: Male Location: Sydney Posted 06/05/10 11:56 PM Share Posted 06/05/10 11:56 PM All my mods have been handling related for my '08 FGXR6T, as it is used on the circuit around 4 times per year.Custom valved Koni reds, Lovell springs, custom made sway bars, Brembos, better tyres (Eagle F1's and R888's etc)So far, the only engine mods have been oil cooler and bigger FPV Tranny cooler for ZF6, plus XR8 intake and K&N panel filter.The car is a daily driver too and I don't want to deal with any rough idling or potentially stalling if I fit bigger injectors and tune. It's always run on 98 fuel.My question is do bigger, say 60lb injectors feel any different from stock at low rpm road speeds or would FPV F6 (42 or 48lb? size?) injectors better suit my application?Eventually I will be fitting a bigger intercooler and 5" 100cpi cat, but that will be it. Not interested in after market exhausts or battery relocations. Would like close to 300rwkw, but no more. Could this be achieved safely with F6 injectors, stock FG turbo and my other mods on a safe lowish boost?Also will these bigger injectors make it safer on the track (I.e. on boost out of high speed corners with half tank) or should I opt for a slightly richer tune. (Don't want to go to the expense/hassle of surge tanks and bigger fuel pumps) Thanks. Link to comment Share on other sites More sharing options...
Benji_vs Donating Members 403 Member For: 16y 10m 2d Gender: Male Location: East Suburbs Melbourne Posted 07/05/10 02:09 AM Share Posted 07/05/10 02:09 AM (edited) In my experience my injectors (60lb) dont feel any different from the stock ones at idle. I do notice it a tiny bit when its cold, but after its warm its the same if not better.It come down to the tune, so get it done properly and you wont have a problem.Also if your going racing id opt for a better pump and surge tanks as its not the injectors what pike it when you come out of corners at hi g's its the pumps ability to pump fuel from a tank which is experiencing high g forces. You will save your engine. Edited 07/05/10 02:12 AM by Benji_vs Link to comment Share on other sites More sharing options...
HIRO F6 Member 1,817 Member For: 16y 1m 18d Gender: Male Location: Brisbane, QLD Posted 07/05/10 04:49 AM Share Posted 07/05/10 04:49 AM Nelson,If your running your car at the track then I would highly recommend getting a surge tank installed. With a larger injector you will not want any occurances of lack of fuel supply.As for injectors, have you realized there are very few FG size injectors on the market and if you were to opt for Siemens DEKA 60lb you will have to space your fuel rail out to fit a BA / BF sized injector.I have recently started supplying a 1000cc injector that is a direct replacement for the FG sized injector and have been very happy with their results. I have a set on my car and recently tuned another FG F6 with these injectors. Low RPM and idle with these injectors have not been affected compared to the stock injectors. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 6m 6d Gender: Male Location: Townsville Posted 07/05/10 06:48 AM Share Posted 07/05/10 06:48 AM A mate has 60lb injectors fitted to his FG XR6T and there have been no problems. He also has a surge tank which I think all would recommend like Hiro has said for you doing track work. Link to comment Share on other sites More sharing options...
HIRO F6 Member 1,817 Member For: 16y 1m 18d Gender: Male Location: Brisbane, QLD Posted 07/05/10 07:15 AM Share Posted 07/05/10 07:15 AM I originally had a set of DEKA 60ld's in my car too and had no issues with them. I'd recommend them also but alot of my FG customers are hesitent to space out the fuel rail. Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 8m 12d Gender: Male Location: Sydney Posted 07/05/10 07:31 AM Author Share Posted 07/05/10 07:31 AM Would I need a surge tank if I just went with FG F6 injectors?I've been doing lots of track days with the stock set up on no less than quarter to half tank.If the tune I get doesn't go too lean (as I'm not concerned with extracting every last kW from a tune), why would I need a surge tank? Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 6m 19d Gender: Male Location: Zombie Birdhouse Posted 07/05/10 07:38 AM Share Posted 07/05/10 07:38 AM a surge tank is good insurance against the standard pump not being able to keep the juice up to the squirters,particularly if the tank is getting low .Simple inertia really Link to comment Share on other sites More sharing options...
HIRO F6 Member 1,817 Member For: 16y 1m 18d Gender: Male Location: Brisbane, QLD Posted 07/05/10 07:46 AM Share Posted 07/05/10 07:46 AM No one needs a surge tank, same as no one needs full comprehensive insurance but if your doing spirited drives around a track then its a precaution that's best to be taken.Same as you dont need coil overs but if your taking the car to the track then im sure you'd agree you would rather have them then not have them.If the competitive spirit gets the better of you at some stage you will want that extra second a lap, the difference between running the car on full weight with a tank of fuel or only filling the car with the amount of fuel you will need. Link to comment Share on other sites More sharing options...
tpinto Donating Members 103 Member For: 16y 3m 6d Gender: Male Location: NSW Posted 07/05/10 10:42 AM Share Posted 07/05/10 10:42 AM (edited) Hey buddy, talking through experiance I had nothing but problems with bigger injectors in my Fg XR6 and ended up with F6 injectors instead . At the moment the car has 341 rwkw with the only mods being F6 intercooler F6 injectors and dump pipe. Edited 07/05/10 10:44 AM by tpinto Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 6m 19d Gender: Male Location: Zombie Birdhouse Posted 07/05/10 10:55 AM Share Posted 07/05/10 10:55 AM are you serious ? F6 Intercooler on the track.Your mods are at the limit IMO.3 hard laps go bang. Go see a proper tuner Link to comment Share on other sites More sharing options...
