Intercooler Tips
lat45
  • Member For: 14y 11m 18d
the exhaust is turbo back with split dump pipe and cheers but I dnt need any piping it all bolts in the same spot but yeh thanks for all ya advice cheersss
  • 4 weeks later...
  On 03/05/2010 at 8:56 AM, icer said:
I got cooler pipes for sale. 600$ for them all.
these pipes
No cooler/core. Will come with clamps and silicon joiners and everything. $650 posted. let me know if your interested. Less then 2000km old. Good for 420-450rwkw~ with the supporting cooler.
Hey mate you still got these pipes for sale
  • 2 weeks later...
  • Suspended
  • Member For: 16y 8m 7d
I put the rapid kit on with the big cooler and underbattery intake with totaly stock car and the afrs were fine and it made 217kw on 5psi(stock map) and 265kw on 10psi(generic flash tune)
changing ya cooler might make a tiny be less restriction but really its just gona keep the air cooler, the intake has a air temp sensor which reads the intake temps and adjust fuel to suit so when the cars cold and you give it some it will run good and then go slower when the intake temps get up with bigger cooler it will just keep the temps lower and run good for longer....
car will go into limp mode if it has stock tune and you try run over 10psi, if you dont change the dump pipe it wont over boost and you should be fine....
