fg turbo ute Member 8 Member For: 16y 5m 24d Gender: Male Location: Cairns.QLD Posted 29/04/10 09:31 PM Share Posted 29/04/10 09:31 PM HI, I OWN AN FG TURBO UTE 08. I DECIDED A WHILE BACK TO BUY THIS INJECTORS AND FLASH TUNER PACKAGE FROM INTUNE MOTORSPORT. SINCE I INSTALLED THE INJECTORS AND LOADED THE TUNE I WAS GETTING STALLING AN ETC FAULTS. SO I GOT A CUSTOM TUNE THINKING THAT IT WAS JUST A DODGY TUNE HOWEVER THE PROBLEM STILL EXISTS. THE CARS BEEN IN FORD SEVERAL TIMES AND THERE ALL SCRATCHING THERE HEADS OVER THE ISSUE. TO ME IT SOUNDS LIKE THE TPS OR THAT IS AT LEAST WHAT THE FAULT IS TELLING ME BUT FORD WONT REPLACE IT UNLESS IT BRINGS A LOGGED DIAGNOSTIC CODE ON THE COMPUTER. IM FED UP WITH THE ISSUE AND JUST NEED A COUPLE A OPINIONS BEFORE GOING OUT AND BUYING THE TPS MYSELF THANKS FOR YOUR HELP Link to comment Share on other sites More sharing options...
BensXR6T Member 478 Member For: 16y 1m 20d Gender: Male Location: Burpengary QLD Posted 29/04/10 09:44 PM Share Posted 29/04/10 09:44 PM Agh ... DON'T USE CAPS , makes it hard to read!!Ford wouldn't know what to do with the car if it's got different injectors in it, I'm surprised they even looked at it under warranty. Take it to a reputable tuner to have the correct scalers put in for the injectors.The problem is obviously with the injectors if you didn't have the problem before installation. If you want to rule out the TPS (which I doubt is a problem) return the car to stock including the injectors and see if the problem goes away. Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 3m 1d Gender: Male Location: Perth Posted 29/04/10 09:59 PM Share Posted 29/04/10 09:59 PM ETC fault is due to the motor flooding maybe / overfuelling... ?? I parked my FG on a steep slope (about 30 degrees give or take a bit), front of car facing down the hill.started the car, and ETC error kicked in.drove it back onto the road, turned car off, turned it back on, and the error was gone. Link to comment Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 21y 10m 4d Gender: Male Location: stanthorpe wine capital of qld. Posted 29/04/10 10:32 PM Share Posted 29/04/10 10:32 PM it still amazes me that you get injectors and a tune and when things go wrong you automatically blame the ford system.If it was ok before you did it then you need to look at what was done first did you leave a wire off some where when the injectors were done.Is there a vacumm leak around the injectors.And as has been mentioned have the injectors been scaled right.If these are ok then look at the ford section.I know from experence that if the tps was causing this fault it should log a code.Ian Link to comment Share on other sites More sharing options...
The_Bogan Donating Members 881 Member For: 17y 10m 23d Gender: Male Location: Brisbane, Queensland Posted 30/04/10 12:04 AM Share Posted 30/04/10 12:04 AM I dare say that it would be tune related. Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 6m 7d Gender: Male Location: Zombie Birdhouse Posted 30/04/10 01:52 AM Share Posted 30/04/10 01:52 AM I dare say you're right. Get a"proper" custom tune from a reputable tuner Link to comment Share on other sites More sharing options...
fg turbo ute Member 8 Member For: 16y 5m 24d Gender: Male Location: Cairns.QLD Posted 01/05/10 11:17 PM Author Share Posted 01/05/10 11:17 PM the car brought up the etc fault when it had about 50kms on the clock, it just got worse after I put the injectors in. ive had the car tuned with a custom tune and it cleared up the issue a little better. although after I got it back from ford last week there the etc fault is a lot more rare just stalling reguarly I mean like 4 times over a 10km period. ford told me they had the injectors out and cleaned them but didnt say a word about them being siemens injectors haha they probably didnt even have them out Link to comment Share on other sites More sharing options...
Wingnut Member 573 Member For: 16y 6m 22d Gender: Male Posted 01/05/10 11:50 PM Share Posted 01/05/10 11:50 PM My car does the same thing and has done since I had it moddified. Mine is most certainly a fueling issue as on cold start I get strong fuel smell and the car seems to stall in the same areas and under the same conditions. For example going down a big hill before a set of lights on the way to work, the car will ALWAYS stall or try to once I come to a stop.Im not happy about it, but she runs perfectly other than that. The tune just needs a little attention I would assume you are having much similar problems. Link to comment Share on other sites More sharing options...
NitroXR6T Member 28 Member For: 16y 8m 15d Posted 02/05/10 04:27 AM Share Posted 02/05/10 04:27 AM Had a stalling issue with mine when I first brought it. Stalling and no error codes. Turns out it was a faulty air flow sensor. All fixed after changing it Link to comment Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 6m 20d Gender: Male Location: Newcastle Posted 02/05/10 10:35 AM Share Posted 02/05/10 10:35 AM With the short time it takes to change injectors (1hr max) I'd put the oem ones back in and flash the standard tune in and go see Ford to fix, if the problem is still there.Benny Link to comment Share on other sites More sharing options...
