  • Member For: 20y 1m 5d
You will need to swap the brakes to standard in any case so that you can run a true slick tyre (and run your car to it's true potential)... This is not an expensive excersise Dario... :icon_ford:
Shock's will cost you over 1K (and you still wont be able to run a full slick without standard brakes), brakes will cost you around $200 from the wreckers :bum: You will own them..
And when you go from 1000 to 1500nm you will still be able to run the same slick instead of throwing your M&T streets in the bin and starting all over again :dontknow:
Edited by SPIKO
