  • Member For: 19y 3m 3d
Blueboost and myself run a 28x10.5 slick. Just gotta have enough height and the car cant squat down to far onto the tire. I ran airbags in the rear to stop the car squatting and I believe blueboost had longer bumpstops to prevent the tire hitting the guard on launch.
https://www.fordxr6turbo.com/forum/topic/67791-slick-size/#findComment-1003659
  • Member For: 15y 11m 1d
thanks for that the brakes on the rear of typhoon are larger than xr6 turbo
15 inch wheel I would need the xr6 rear brakes is that right .and taller springs. the gaurds are liped already so what other mods do I need.
https://www.fordxr6turbo.com/forum/topic/67791-slick-size/#findComment-1003728
  • Member For: 20y 24d
Hey mate,
Markvan & Blueboost do run 28x10.5 however they do not fit under the guards, you will need to lift the rear about 4 to five inch's so that it doesn't squat and hit the tire....
How much larger are the rear brakes?
A proper offset 28x9 will fit under the guard's and require no need for lifting the rear, there is a swing arm that goes from the body (near the back door) to the rear disk assembly, you will need to insert a 5 to 8mm spacer on this swing arms floating joint, this in turn will move your assembly inwards allowing the 28x9 to fit well under the guards.. :bum:
Edited by SPIKO
https://www.fordxr6turbo.com/forum/topic/67791-slick-size/#findComment-1003729
  • Member For: 19y 7m 18d
Dario,
I just saw the torque curve... I think that you are going to need more rubber on the rears!
The car has a flat "factory like" torque curve but with a bit more torque.
Actually much more torque!! It has over 1000nm from 3000 - 5200 rpm!
https://www.fordxr6turbo.com/forum/topic/67791-slick-size/#findComment-1003846
there is heaps of torque but the street radials that im using are suppose to be very good. I need to change all the rear break set up because its to big to fit 15 or 16 inch rims and then taller springs to get those 28 s under
https://www.fordxr6turbo.com/forum/topic/67791-slick-size/#findComment-1003861
I am listerning. typhoon has bigger brakes and the 17 inch wheels just fit over with a bit of grinding on rear caliper.
do they do a 28 tall in a 17 inch rim.
https://www.fordxr6turbo.com/forum/topic/67791-slick-size/#findComment-1004079
