TerryF Member 125 Member For: 16y 7m Gender: Male Location: Brisbane Posted 26/04/10 03:18 AM Author Share Posted 26/04/10 03:18 AM Great stuff, keep it coming.. Link to comment https://www.fordxr6turbo.com/forum/topic/67768-psi-to-power-comparison/page/2/#findComment-1003340 Share on other sites More sharing options...
BensXR6T Member 478 Member For: 16y 3m 26d Gender: Male Location: Burpengary QLD Posted 26/04/10 03:52 AM Share Posted 26/04/10 03:52 AM On 26/04/2010 at 12:53 AM, berzerker said: Then once some better flowing mods get bolted on the tuners can up the power and retain or even lower the current boost level. Am I right?15psi through a restrictive intake allows less air then a free flowing system.eg. 2" pipe @ 15psi will flow a hell of a lot less air then a 3" pipe at the same compression.It's not just about the compression of the air, but also how much air can be flowed through. My car @12psi with the HDi cooler would be combusting a lot more air then it would have been when it was at 15psi with the monza cooler cos more air gets compressed before it hits the boost level programmed in. More air = more fuel = bigger bang.Hope that makes sense Link to comment https://www.fordxr6turbo.com/forum/topic/67768-psi-to-power-comparison/page/2/#findComment-1003343 Share on other sites More sharing options...
MeatWod Member 51 Member For: 17y 11m 15d Gender: Male Location: Baldivis Posted 26/04/10 04:52 AM Share Posted 26/04/10 04:52 AM 18PSI 361kw = 20.05rapid 3.5, full 4" smb zorst with 5" cat 60lb squirters Link to comment https://www.fordxr6turbo.com/forum/topic/67768-psi-to-power-comparison/page/2/#findComment-1003348 Share on other sites More sharing options...
bradles024 Donating Members 1,145 Member For: 15y 5m 18d Gender: Male Posted 26/04/10 06:05 AM Share Posted 26/04/10 06:05 AM 303@15psi, 20.2kw/psi with standard intake/crossover. Link to comment https://www.fordxr6turbo.com/forum/topic/67768-psi-to-power-comparison/page/2/#findComment-1003360 Share on other sites More sharing options...
whistler6 Member 417 Member For: 17y 8m 3d Gender: Male Location: VIC Posted 26/04/10 08:16 AM Share Posted 26/04/10 08:16 AM 379rwkw @ 16psi Link to comment https://www.fordxr6turbo.com/forum/topic/67768-psi-to-power-comparison/page/2/#findComment-1003384 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 4m 16d Gender: Male Posted 26/04/10 10:54 AM Share Posted 26/04/10 10:54 AM 258rwkw @ 10psi: BMC filter, typhoon secondary snorkel, stock plugs, generic tunesince then I've put in a monza cooler and .8mm plugs. looking to get some 60lb injectors, fuel pump, 100cpi cat before getting a custom tune. Link to comment https://www.fordxr6turbo.com/forum/topic/67768-psi-to-power-comparison/page/2/#findComment-1003444 Share on other sites More sharing options...
TerryF Member 125 Member For: 16y 7m Gender: Male Location: Brisbane Posted 26/04/10 11:06 AM Author Share Posted 26/04/10 11:06 AM On 26/04/2010 at 10:54 AM, JC807 said: 258rwkw @ 10psi: BMC filter, typhoon secondary snorkel, stock plugs, generic tunesince then I've put in a monza cooler and .8mm plugs. looking to get some 60lb injectors, fuel pump, 100cpi cat before getting a custom tune.Cool remember to get a tune after you install all of them. Link to comment https://www.fordxr6turbo.com/forum/topic/67768-psi-to-power-comparison/page/2/#findComment-1003446 Share on other sites More sharing options...
Lynchy Member 115 Member For: 16y 3m 27d Gender: Male Location: Albury/Wodonga Posted 26/04/10 11:55 AM Share Posted 26/04/10 11:55 AM 342.5rwkw on 14psi with mods in my sig.... Link to comment https://www.fordxr6turbo.com/forum/topic/67768-psi-to-power-comparison/page/2/#findComment-1003458 Share on other sites More sharing options...
