Fg Xrt Valve Springs
ba_xr6_turbo
  • Member For: 21y 6m 6d
Pretty sure Ray076 had his fitted by a shop in Mackay for $500 but will get him to reply with actual cost.
His were floating on the FG every now and then when giving it a gut full with the 330rwkw ish he had...
  • Replies 27
  • Member For: 19y 4m 25d
I have seen 3 brand new fg f6's 2 with exhaust and tune and one with just tune valve float with under 300kwatw when I worked at autotech the stock one valve floated std with no tune so there is a issue there with them wouldn't suprise me if ford has cut corners on valve spring quality.
My 2 cents worth
Cheers Neil
  • Member For: 18y 9m 18d
We pushed 370wkws from my G6 before the springs gave up, so up to 16psi was fine (370kw), on 20psi there was minor float on the dyno but massive valve bounce on the road.
So do them if your going to run high boost.
  • Member For: 15y 21d
sweet,
Rapid what did you do to get 370?
Presuming the standard turbo gave up at around 320?
Edited by kvbaby
yeah we sqeezed 340ish from the stocker.
It has low mount GT4596R turbo, 50mm external wastegate, V2.0 intcooler/intake/bat swap kit, 3.5inch stainless exhaust, 60lb Siemens injs, twin 044 fuel system
Currently doing valve springs, head studs and loads more boost, tuning at Crescent Motorsport
  • 5 months later...
hey all,
can anyone give me an insight into what valve float feels like, while hard driving?
I'm trying to diagnose a problem atm.
Cheers
Edited by kvbaby
  • Member For: 16y 3m 14d
valve float usually occurs at high rpm, with the valves floating the cylinder its occuring on becomes useless. and in effect makes the engine miss on that cylinder. engine vibrations, coughing, lack of wanting to rev all are associated with valve float. once it occurs usually it will continue to make the engine miss till you have brought it off boost.
its something that when it happens you know its not right.
what boost and kw are you running to get the valve float?
I was pushing 17psi and anymore than that it would float very bad. that was at 320rwkw and now am pushing 350rwkw on 11.5 psi with no float at all.
