Diff Oil Change
ALF05T
  • Member For: 18y 2m 22d
Hi all
This may seem like a dumb question but can anyone tell me where the fill point is on the diff housing?
Also I presume the drain point would be the lowest flange bolt, would this be correct?
Cheers Alf.
  • Member For: 15y 5m 11d
I'm slightly built so it's easy for me. have you got a sedan or ute, if you have a sedan you will need some way of getting the oil from the bottle to the diff.
  • Member For: 17y 3m 15d
Just get some of the clear flexible hose at Bunnings and run it from the diff to outside one of the wheel arches (driver's side is easiest). Should be easy to fill then as the Castrol synthetic diff oil (SAF-XA) these cars run is not as thick as the old stuff used to be. The best size is one that almost fills the hole.
Drain bolt is bottom one on the alloy tail housing. I have put some Nulon diff treatment in mine instead of the expensive Lubrizol that Ford recommend and it has not chattered on tight turns once since then. LSD action still good with equal black stripes :bangcomputer:
Edited by Smoke them tyres
  • 8 months later...
  • <put funny sh*t here>
  • Member For: 18y 4m 28d
Tried this today, excellent idea!! I used to use a suction pump and do it in like 10 goes to fill it up.
now I just got a fat clear rubber hose, fed it through the rear driver side rim, through the suspension and straight into the filler hole.
then I just held up the tube from outside the car, and poured the bottles in. the castrol SAF-XA bottle has the nozzle which fit tightly into the tube, and when I pushed the bottle it forced it down the tube. to empty the tube for removal, I just squeezed the empty bottle into the tube and the air pressure fed it all through the tube into the diff.
much easier idea, thanks for the tip!
Edited by RHR
No need to quote above post. USE FAST REPLY
