RegSpec Cruise Control 1,417 Member For: 18y 5m 23d Gender: Male Location: Macksville NSW. Posted 12/04/10 10:35 AM Author Share Posted 12/04/10 10:35 AM If the difference is in the ABS system....how come all the test functions relating to this work ok and its only the engine oil pressure warning that gives a problem? Just makes no sense to me is all..... Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/page/2/#findComment-999959 Share on other sites More sharing options...
ORSMBA ORSM Ford Cruisers! Donating Members 319 Member For: 20y 21d Gender: Male Location: Melbourne Posted 13/04/10 12:42 PM Share Posted 13/04/10 12:42 PM You are right it doesnt, but I have run into this situation before with a Turbo Territory, even though we had installed a BF series FPV cluster the OIL light would constantly come on. I ended up modifying the original cluster to the FPV Fascia. Personally I cant understand why it would be so as the Oil Alarm is driven from the same CAN message on all B series according to the manuals, but there may have been a variation maybe later in the BF Series.But what I was saying with the BA Cluster, It will simply not work regardless as you will never receive an ABS or Brake Fail alarm on your cluster if you install a BA cluster into a BF. A BA Clusters ABS and Brake Fail lights are hardwired and 12V is applied to the inputs from the ABS/Brake system when they fail.Now because the BF's ABS communicates to the PCM etc via the Can or ISO bus (cant remember which) the ABS/Brake fail alarms are driven from messages sent to the cluster and are not hardwired. BF wiring will not have the ABS/Brake fail wiring to the cluster. Mind you a BF cluster can be fitted to a BA as with the BF Cluster there is a programming feature that allows you to switch from BF style to BA.I hope this makes things a bit clearer.Matt Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/page/2/#findComment-1000246 Share on other sites More sharing options...
RegSpec Cruise Control 1,417 Member For: 18y 5m 23d Gender: Male Location: Macksville NSW. Posted 13/04/10 02:00 PM Author Share Posted 13/04/10 02:00 PM On 13/04/2010 at 12:42 PM, ORSMBA said: Now because the BF's ABS communicates to the PCM etc via the Can or ISO bus (cant remember which) the ABS/Brake fail alarms are driven from messages sent to the cluster and are not hardwired. BF wiring will not have the ABS/Brake fail wiring to the cluster. Mind you a BF cluster can be fitted to a BA as with the BF Cluster there is a programming feature that allows you to switch from BF style to BA.I hope this makes things a bit clearer.Matt Ahh Haa!!.....that's what it is ....a mate fitted a BF cluster to his BA and had no problems. We just couldn't figure why it wouldn't work the other way around Thanks ORSMBA....the above explains why....looks like Im off to the wreckers for a BF cluster......thanks again mate Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/page/2/#findComment-1000263 Share on other sites More sharing options...
