RegSpec Cruise Control 1,417 Member For: 18y 5m 18d Gender: Male Location: Macksville NSW. Posted 10/04/10 10:31 AM Share Posted 10/04/10 10:31 AM I changed the instrument cluster in my car and now the oil warning light and chime won't go out..... Ive added gauges to the car and I know its got plenty of pressure so what can I do to get rid of the light? Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/ Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 9m 10d Gender: Male Location: Southern Highlands NSW Posted 10/04/10 10:36 AM Share Posted 10/04/10 10:36 AM FPV dash?Might have to get ford to update it Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/#findComment-999366 Share on other sites More sharing options...
RegSpec Cruise Control 1,417 Member For: 18y 5m 18d Gender: Male Location: Macksville NSW. Posted 10/04/10 11:00 AM Author Share Posted 10/04/10 11:00 AM Update what?? Everything else works perfectly....tach, speedo other gauges and warning lights... How come you've got to "update" the thing just for ONE warning light??? If it wasn't for the damn chime....I could just stick a bit of tape over the light and off we'd go..... Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/#findComment-999373 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 8d Gender: Male Location: SW Sydney Posted 11/04/10 06:29 AM Share Posted 11/04/10 06:29 AM When you put the gauges in Reg, did you change the oil pressure sender? Or do you run the sender unit for the gauge on a T-piece with the original low pressure switch? Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/#findComment-999542 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 2d Gender: Male Location: Sydney Posted 11/04/10 07:16 AM Share Posted 11/04/10 07:16 AM I seem to remember that when you change from a low series (stock XR) to a high series (FPV/Lux pack) dash, you need to get Ford to update the ECU to the changes.It was a few years ago, might want to try a search. Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/#findComment-999562 Share on other sites More sharing options...
RegSpec Cruise Control 1,417 Member For: 18y 5m 18d Gender: Male Location: Macksville NSW. Posted 11/04/10 09:44 AM Author Share Posted 11/04/10 09:44 AM On 11/04/2010 at 6:29 AM, senna_T said: When you put the gauges in Reg, did you change the oil pressure sender? Or do you run the sender unit for the gauge on a T-piece with the original low pressure switch? Its got a "T" piece deal with both senders in it..... I tried disconnecting the light sender and it made no difference... Zap....they are both low series clusters. Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/#findComment-999612 Share on other sites More sharing options...
ORSMBA ORSM Ford Cruisers! Donating Members 319 Member For: 20y 17d Gender: Male Location: Melbourne Posted 11/04/10 10:43 AM Share Posted 11/04/10 10:43 AM Ive seen this issue on a couple of clusters before. what is the part number etc of you old and new cluster?Matt Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/#findComment-999660 Share on other sites More sharing options...
RegSpec Cruise Control 1,417 Member For: 18y 5m 18d Gender: Male Location: Macksville NSW. Posted 11/04/10 01:13 PM Author Share Posted 11/04/10 01:13 PM I'll pull it out (again) tomorrow and post the no's ok Matt.thanks Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/#findComment-999698 Share on other sites More sharing options...
RegSpec Cruise Control 1,417 Member For: 18y 5m 18d Gender: Male Location: Macksville NSW. Posted 12/04/10 02:57 AM Author Share Posted 12/04/10 02:57 AM Part No. on original cluster is 5R29 10849 DA Part No. on cluster I want to fit is 3R23 10849 DE. Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/#findComment-999778 Share on other sites More sharing options...
ORSMBA ORSM Ford Cruisers! Donating Members 319 Member For: 20y 17d Gender: Male Location: Melbourne Posted 12/04/10 08:33 AM Share Posted 12/04/10 08:33 AM There lies the problem, the cluster you want to install is from a BA, it will not function in a BF correctly. BF series cars use a different ABS system compared to the BA's so it will constantly alarm.Only way to fix it is to get a BF cluster or modify your own.Matt Link to comment https://www.fordxr6turbo.com/forum/topic/67475-oil-light-warning/#findComment-999892 Share on other sites More sharing options...
