robbiefisher Member 10 Member For: 14y 11m 18d Posted 02/04/10 04:53 AM Share Posted 02/04/10 04:53 AM Guys, Please give me some idea about repainting the cross over, large areas of paint has peeled off.Does it come up satisfactory ?What type of paint would I use?Is it a better proposition to buy new ?regards robbiefisher Link to comment Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 6m 10d Gender: Male Location: Melbourne, VIC Posted 02/04/10 06:16 AM Share Posted 02/04/10 06:16 AM The best proposition would be to get rid of the restrictive bastard.. Link to comment Share on other sites More sharing options...
BensXR6T Member 478 Member For: 16y 1m 24d Gender: Male Location: Burpengary QLD Posted 02/04/10 07:13 AM Share Posted 02/04/10 07:13 AM Stock crossover is good for about 480rwhp, but you can make power easier without it. However he may not be chasing the huge numbers some of us are after.You will have to strip it completely to get a good finish, bit of paint stripper should do the trick.Just use some high temp paint on it and go whatever colour you want. Brake calliper or engine enamel will do the trick, the key is preparation. If your base coat is perfect then it will be alot easier to make the colour coat look good. Just follow the directions on the can you buy for prep work.Good luckCheers,Ben Link to comment Share on other sites More sharing options...
KIL-06L Member 155 Member For: 15y 10m 5d Gender: Male Location: Sydney Posted 02/04/10 11:30 AM Share Posted 02/04/10 11:30 AM you should use hi temp paint to freshen it up. or I hav a very good condition one that you can hav for $50 if your in the syd area??? Link to comment Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 16y 4d Gender: Male Posted 05/04/10 11:42 PM Share Posted 05/04/10 11:42 PM The question is: Is it peeling on the inside also? I'd check this if you dont want bent turbo vanes... Link to comment Share on other sites More sharing options...
robbiefisher Member 10 Member For: 14y 11m 18d Posted 23/04/10 02:04 PM Author Share Posted 23/04/10 02:04 PM Thankyou Guys, It is external paint finish, I will try sanding and apply some wrinkly finish VHT Paint, if that fails I'll look to the wreckers for a better example.thankyou again Link to comment Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 18y 11m 6d Gender: Male Location: nsw Posted 23/04/10 03:06 PM Share Posted 23/04/10 03:06 PM there have been cases posted on here where internal paint and casting dags have damaged turbo`s. Link to comment Share on other sites More sharing options...
robbiefisher Member 10 Member For: 14y 11m 18d Posted 23/04/10 11:01 PM Author Share Posted 23/04/10 11:01 PM Thankyou BFHoon, I'll take the crossover off and check its internals then give it a coat.regards robbiefisher Link to comment Share on other sites More sharing options...
