Jeremy Member 112 Member For: 17y 1d Gender: Male Location: Perth mindaz Posted 28/03/10 05:12 AM Share Posted 28/03/10 05:12 AM Went to start my turbo this mourning and it started to turn over then just died... I turned it off then tryed to start it again and nothing.. Allthe acessories are working... Battery is fine and I ran my flash tuner through it and reloaded the tune.. Still didn't work!! I'm thinking starter motor.. But I'm not that mechanically minded so does any1 have any suggestions?? Cheers guys Link to comment https://www.fordxr6turbo.com/forum/topic/67187-car-wont-start-been-running-fine/ Share on other sites More sharing options...
Boosted1 Member 346 Member For: 16y 4m 21d Posted 28/03/10 05:25 AM Share Posted 28/03/10 05:25 AM could be alot of things mate. does it turn over? if so is the fuel pump priming? use your flsh to scan the fault codes Link to comment https://www.fordxr6turbo.com/forum/topic/67187-car-wont-start-been-running-fine/#findComment-995581 Share on other sites More sharing options...
Jeremy Member 112 Member For: 17y 1d Gender: Male Location: Perth mindaz Posted 28/03/10 05:48 AM Author Share Posted 28/03/10 05:48 AM Nah it doesn't turn over.. Yeh u can hear the fuel pump when it goes to the "on" position.. It just won't kick over.. How do I use my flash tuner to scan for fault codes? Link to comment https://www.fordxr6turbo.com/forum/topic/67187-car-wont-start-been-running-fine/#findComment-995586 Share on other sites More sharing options...
tinyplums Member 1,080 Member For: 16y 8m 10d Gender: Male Posted 28/03/10 06:03 AM Share Posted 28/03/10 06:03 AM how do you kow your battery is fine? Link to comment https://www.fordxr6turbo.com/forum/topic/67187-car-wont-start-been-running-fine/#findComment-995591 Share on other sites More sharing options...
Jeremy Member 112 Member For: 17y 1d Gender: Male Location: Perth mindaz Posted 28/03/10 06:52 AM Author Share Posted 28/03/10 06:52 AM Well all the lights and acessories working...I havnt done a voltage check cause I don't have one of the meters to check... Link to comment https://www.fordxr6turbo.com/forum/topic/67187-car-wont-start-been-running-fine/#findComment-995599 Share on other sites More sharing options...
Jeremy Member 112 Member For: 17y 1d Gender: Male Location: Perth mindaz Posted 29/03/10 03:02 AM Author Share Posted 29/03/10 03:02 AM Any1? Link to comment https://www.fordxr6turbo.com/forum/topic/67187-car-wont-start-been-running-fine/#findComment-995845 Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 16y 1m 18d Gender: Male Posted 29/03/10 03:53 AM Share Posted 29/03/10 03:53 AM Do you hear a noise like "tik...tik..tiktiktiktik.." when you are trying to start it or nothing at all?Turn your lights on, if they die when you try to start the engine, its your battery. Link to comment https://www.fordxr6turbo.com/forum/topic/67187-car-wont-start-been-running-fine/#findComment-995869 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 8m 28d Gender: Male Location: Aspendale, Vic. Posted 29/03/10 04:03 AM Share Posted 29/03/10 04:03 AM did u play with any plugs near the head lights on driver side? I know there are those 2 big plugs male>female that need to be intact.Else, id say starter motor. Call an auto elec. Link to comment https://www.fordxr6turbo.com/forum/topic/67187-car-wont-start-been-running-fine/#findComment-995876 Share on other sites More sharing options...
tinyplums Member 1,080 Member For: 16y 8m 10d Gender: Male Posted 29/03/10 04:36 AM Share Posted 29/03/10 04:36 AM have you tried changing/charging the battery. it will still work your lights and accesories, but wont have enuff juice to turn the motor over. Link to comment https://www.fordxr6turbo.com/forum/topic/67187-car-wont-start-been-running-fine/#findComment-995890 Share on other sites More sharing options...
Dirty32 Legendary member!! Donating Members 1,739 Member For: 18y 2m 23d Gender: Male Location: Dianella, West Oz Posted 29/03/10 04:41 AM Share Posted 29/03/10 04:41 AM Could be battery, spark or fuel delivery...Good possibility it isnt, but just throwing it out there - its not common, in fact I havent heard or read of it happening before but it happened to me. Have your Crank Angle Sensor checked.My ute was running fine, all of a sudden it wouldnt start.Problem was, it wasnt throwing any codes when diagnosed.Checked battery, spark & fuel system and it was only when literally everything was checked with a multimeter, we found out it was the CAS. Still to this day not quite sure why that happened, but it did.Best of luck - let us know when you find out! Link to comment https://www.fordxr6turbo.com/forum/topic/67187-car-wont-start-been-running-fine/#findComment-995892 Share on other sites More sharing options...
