simmo Member 431 Member For: 22y 4m 14d Gender: Male Location: byron bay more underarm hair per square km Posted 26/03/10 12:25 PM Share Posted 26/03/10 12:25 PM (edited) hey I have a ba mk1 5 speed what is the best gear oil to useive heard transmax z oil is good. Edited 26/03/10 12:25 PM by simmo Link to comment https://www.fordxr6turbo.com/forum/topic/67172-ba-mk1-gearbox-oil/ Share on other sites More sharing options...
MaTTe Member 143 Member For: 16y 7m 21d Location: Perth Posted 27/03/10 01:38 PM Share Posted 27/03/10 01:38 PM I used Redline Light Shock, and Microglide addative. The light shock tested almost as well as the microglide on the pressure wheel. I haven't tested transmax on the pressure wheel, but it still doesn't make sense to me putting auto trans fluid into a manual transmission. Link to comment https://www.fordxr6turbo.com/forum/topic/67172-ba-mk1-gearbox-oil/#findComment-995475 Share on other sites More sharing options...
f-wolf Member 897 Member For: 18y 1m 29d Gender: Male Location: ACT Posted 28/03/10 03:26 AM Share Posted 28/03/10 03:26 AM On 27/03/2010 at 1:38 PM, MaTTe said: I used Redline Light Shock, and Microglide addative. The light shock tested almost as well as the microglide on the pressure wheel. I haven't tested transmax on the pressure wheel, but it still doesn't make sense to me putting auto trans fluid into a manual transmission." ATF because gear oil was not able to properly penetrate the small, caged, needle bearings "And Posted 22 February 2007 " I emailed Bob Hanlon at Halon Motor Sports (T5, Temec transmissions); he said that the ONLY Redline product that could be used in a world class T5 is the Redline ATF called D-4. The Redline gear oil, 75W90NS, will not lubricate the needle bearings in a WC T5." Link to comment https://www.fordxr6turbo.com/forum/topic/67172-ba-mk1-gearbox-oil/#findComment-995560 Share on other sites More sharing options...
