Ray076 Member 64 Member For: 15y 9m 13d Gender: Male Location: NQLD Posted 01/07/10 12:10 PM Share Posted 01/07/10 12:10 PM stock turbo and actuator limit I believe is where im roughly at which is 330rkw. All I have is 4 inch intake, 3.5 x force system, pwstage 2 intercooler,60lb injectors and surge tank for insurance. The actuator is quite good. Im about to fit a bigger turbo to replace the smaller FG and my tuner (Blueboost)says he might use the same actuator. So the car will be hopefully pushing 380rwkw with stock actuator. Will keep you posted on how it goes. And with the valve springs im only just now doing them with the turbo now for insurance. So they still good for a bit. Hope this helps.. Link to comment Share on other sites More sharing options...
djkice Boost Addict Member 1,273 Member For: 16y 7m 7d Gender: Male Location: Perth, W.A. Posted 01/07/10 04:55 PM Share Posted 01/07/10 04:55 PM hey ray, the turbo I supplied came with upgraded actuator, 12psi I think from memory and a nicely ported rear housing. you should haven o issues. Link to comment Share on other sites More sharing options...
Dyno Junkie Member 254 Member For: 17y 11m 12d Gender: Male Location: Ascot, Western Australia Posted 02/07/10 12:57 AM Share Posted 02/07/10 12:57 AM Our TTG is making 321AWKW, which is probably mid 350RWKW in a rear wheel drive car.This is with a stock turbo and holds steady 15-15.5psi. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 5m 25d Gender: Male Location: Townsville Posted 02/07/10 01:34 AM Share Posted 02/07/10 01:34 AM hey ray, the turbo I supplied came with upgraded actuator, 12psi I think from memory and a nicely ported rear housing. you should haven o issues.Hi djkice,Yeah Ray knows this with the turbo you supplied but some tuners say there have been boost spiking with the 12psi actuators. Dave will still prob use the standard one from the smaller turbo being roughly 8psi or close.He is keen and so am I to see what it has! Link to comment Share on other sites More sharing options...
djkice Boost Addict Member 1,273 Member For: 16y 7m 7d Gender: Male Location: Perth, W.A. Posted 02/07/10 10:27 AM Share Posted 02/07/10 10:27 AM well I had issues with spiking, changed to 3 different actuators, 3 different exhaust housing ported differently.the final port which is on there now works perfectly with the 12psi actuator, but dave knows what hes doing... good luck! Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 5m 25d Gender: Male Location: Townsville Posted 03/07/10 12:14 AM Share Posted 03/07/10 12:14 AM Sweet. Cheers Link to comment Share on other sites More sharing options...
