Tps Unit Replaced
  • Member For: 17y 9m 23d
EBAY Australia
Got the one I just fitted for $ 83.95. About 1 hour ago I got a 2nd one for $92.00. I like to have a spare. :)
* The only other ones I can see are here:
THROTTLE POSITION SENSOR (TPS) FORD BA BF TERRITORY - eBay Other, Engines, Components, Car Parts, Accessories, Cars, Bikes, Boats. (end time 18-Mar-10 21:39:31 AEDST)
Edited by revheadrobbo
no need to quote above post
  • Member For: 15y 1m 3d
Yeah, that's the one I seen the other day :-) bit rich for my liking. I will have to keep an eye out. My car was having idle issues, but pulling throttle body off and giving her a bit of TLC with nulon CC did the job nicey :-) Although it would be good to replace the TPS as mine is also the old dimple style.
  • 4 weeks later...
  • Member For: 18y 1m 2d
Has anyone replaced the TPS within the accelerator module under the dash. I have also replaced the TPS on the throttle body, coil packs, plugs, oxygen sensor. I have this annoying fault (check engine light) comes on after 3000rpm and stays on for about 1 sec after you lift the accelerator pedal.
I have been told to replace the TPS under the dash but the brake booster has to be moved forward and a whole lot of other stuff removed to access this unit. Can anyone else confirm this?
  • 3 weeks later...
