ab_futura Member 21 Member For: 18y 5d Gender: Male Posted 14/03/10 12:30 PM Share Posted 14/03/10 12:30 PM I was talking to an engine builder for advice on oil pump gears and harmonic balancers and he explained to me the reason the oil pump gears fail is because of bad harmonics from the engine weakening the gears in the pump. He said to me the oil pump itself is fine as long as I install a top quality harmonic balancer. This make's sense but my concern is that my engine is out of a wreck that took a massive hit into a poll. Should I be worried about the impact weakening the oil pump gears? Should I buy a new oil pump to be on the safe side? Can anybody tell me roughly what a standard oil pump would cost compared to one with billet gears? It's very easy to say just replace it to be safe, but I don't want to waste my money if there is no need to. The motor has only done 27000kms is currently on on engine stand. Link to comment https://www.fordxr6turbo.com/forum/topic/66895-oil-pump-and-harmonic-balancer-advice/ Share on other sites More sharing options...
cobramad Member 824 Member For: 19y 11m 5d Gender: Male Location: Perth Posted 14/03/10 02:17 PM Share Posted 14/03/10 02:17 PM Most of the guys replacing the oil pump gears really hammer their engines, and that's when the standard cast gears crack and there goes your motor. In your position, I would look at how hard you intend to beat up on the engine, if its lots then billet gears are good insurance. Many big HP T's and 6's still run the factory gears.. In your position, especially if you are considering a new oil pump anyway, I would find the bucks for the quality stuff, you will never have to worry about them failing from then on. And a brand new Genuine pump.. Just my humble opinion dude,Cheers,Mal K Link to comment https://www.fordxr6turbo.com/forum/topic/66895-oil-pump-and-harmonic-balancer-advice/#findComment-991097 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 30d Gender: Male Location: Central Queensland Posted 14/03/10 08:24 PM Share Posted 14/03/10 08:24 PM I already have my Koneski gears sitting here. I keep seeing in posts that the pump is modified.. What is done exactly and how much does the pump and mods cost? Link to comment https://www.fordxr6turbo.com/forum/topic/66895-oil-pump-and-harmonic-balancer-advice/#findComment-991109 Share on other sites More sharing options...
RUS531 RUS531 Donating Members 410 Member For: 18y 10m 4d Gender: Male Location: Emerald QLD Posted 15/03/10 09:55 AM Share Posted 15/03/10 09:55 AM (edited) While the gears are crap in our oil pumps keep in mind that there are pumps out there that have failed due to the housing cracking because it cannot handle the pressure the pump creates under higher rpm. That is the reason why atomic modiy their pumps as such Edited 15/03/10 09:56 AM by RUS531 Link to comment https://www.fordxr6turbo.com/forum/topic/66895-oil-pump-and-harmonic-balancer-advice/#findComment-991293 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 30d Gender: Male Location: Central Queensland Posted 15/03/10 11:23 AM Share Posted 15/03/10 11:23 AM Do you have any idea of the costs for the said housings? It would be handy to know so that I can budget accordingly... Does anyone have a contact number for Atomic? Link to comment https://www.fordxr6turbo.com/forum/topic/66895-oil-pump-and-harmonic-balancer-advice/#findComment-991362 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 10m 6d Gender: Male Location: Broady, Melbourne Posted 15/03/10 01:42 PM Share Posted 15/03/10 01:42 PM Oil pressure is limited on the Atomic units which are tested to 7500rpm. They also come with a billet backing plate for thrust wear resistance. Retail prices are on the Atomic website.Atomic Performance Parts - Performance through innovation - Link to comment https://www.fordxr6turbo.com/forum/topic/66895-oil-pump-and-harmonic-balancer-advice/#findComment-991409 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 30d Gender: Male Location: Central Queensland Posted 15/03/10 08:00 PM Share Posted 15/03/10 08:00 PM Thanks Steph.. Link to comment https://www.fordxr6turbo.com/forum/topic/66895-oil-pump-and-harmonic-balancer-advice/#findComment-991429 Share on other sites More sharing options...
apache_dj Member 145 Member For: 20y 22d Location: Auckland NZ Posted 31/03/10 11:42 PM Share Posted 31/03/10 11:42 PM Hi Guys, Are the FG oil pumps any better than the earlier models? Link to comment https://www.fordxr6turbo.com/forum/topic/66895-oil-pump-and-harmonic-balancer-advice/#findComment-996696 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 5m 10d Gender: Male Location: QLD Posted 15/08/10 01:52 PM Share Posted 15/08/10 01:52 PM Does anyone know what mods aomic does to the pump as Im looking at getting onebut can't justify the extra cost they are charging ifs its just for a billet backing thrust plate & a softer rate releif spring.Or have they just machined the releif hole to a closer open position to give earlier releif and extra volume of releif?Even if they have done all the above I think it is a bit pricy as I have seen complete Sierra Cosworthrace pumps cheaper than the Billet Gears and probably of better quality than the falcon ones. even afterthe Atomic mods.As for Harmonic Balancers I think I saw on there Web site, Ross claim there Metal Jacket series are the best on the market Link to comment https://www.fordxr6turbo.com/forum/topic/66895-oil-pump-and-harmonic-balancer-advice/#findComment-1032788 Share on other sites More sharing options...
aussie_dozer Blown Happiness Donating Members 130 Member For: 16y 27d Gender: Male Location: Queanbeyan NSW Posted 05/12/10 11:02 AM Share Posted 05/12/10 11:02 AM Hey guys,Did any one find out any more about this? I'm very interested as I am going to need to do this in the next round of mods.01TXR - did you find a cheaper alternative? Link to comment https://www.fordxr6turbo.com/forum/topic/66895-oil-pump-and-harmonic-balancer-advice/#findComment-1061023 Share on other sites More sharing options...
