Oil Pump And Harmonic Balancer Advice
ab_futura
  • Member For: 17y 7m 11d
I was talking to an engine builder for advice on oil pump gears and harmonic balancers and he explained to me the reason the oil pump gears fail is because of bad harmonics from the engine weakening the gears in the pump. He said to me the oil pump itself is fine as long as I install a top quality harmonic balancer. This make's sense but my concern is that my engine is out of a wreck that took a massive hit into a poll. Should I be worried about the impact weakening the oil pump gears? Should I buy a new oil pump to be on the safe side? Can anybody tell me roughly what a standard oil pump would cost compared to one with billet gears? It's very easy to say just replace it to be safe, but I don't want to waste my money if there is no need to. The motor has only done 27000kms is currently on on engine stand.
  • Member For: 19y 6m 11d
Most of the guys replacing the oil pump gears really hammer their engines, and that's when the standard cast gears crack and there goes your motor. In your position, I would look at how hard you intend to beat up on the engine, if its lots then billet gears are good insurance. Many big HP T's and 6's still run the factory gears.. In your position, especially if you are considering a new oil pump anyway, I would find the bucks for the quality stuff, you will never have to worry about them failing from then on. And a brand new Genuine pump.. Just my humble opinion dude,
Cheers,
Mal K
  • Member For: 18y 8m 5d
I already have my Koneski gears sitting here. I keep seeing in posts that the pump is modified.. What is done exactly and how much does the pump and mods cost?
  • RUS531
  • Member For: 18y 5m 10d
While the gears are crap in our oil pumps keep in mind that there are pumps out there that have failed due to the housing cracking because it cannot handle the pressure the pump creates under higher rpm. That is the reason why atomic modiy their pumps as such
Edited by RUS531
Do you have any idea of the costs for the said housings? It would be handy to know so that I can budget accordingly... Does anyone have a contact number for Atomic?
  • Member For: 17y 5m 12d
Oil pressure is limited on the Atomic units which are tested to 7500rpm. They also come with a billet backing plate for thrust wear resistance. Retail prices are on the Atomic website.
Atomic Performance Parts - Performance through innovation -
  • 3 weeks later...
  • 4 months later...
  • Member For: 18y 16d
Does anyone know what mods aomic does to the pump as Im looking at getting one
but can't justify the extra cost they are charging ifs its just for a billet backing thrust plate & a softer rate releif spring.
Or have they just machined the releif hole to a closer open position to give earlier releif and extra volume of releif?
Even if they have done all the above I think it is a bit pricy as I have seen complete Sierra Cosworth
race pumps cheaper than the Billet Gears and probably of better quality than the falcon ones. even after
the Atomic mods.
As for Harmonic Balancers I think I saw on there Web site, Ross claim there Metal Jacket series are the best on the market
  • 3 months later...
  • Blown Happiness
  • Member For: 15y 8m 2d
Hey guys,
Did any one find out any more about this? I'm very interested as I am going to need to do this in the next round of mods.
01TXR - did you find a cheaper alternative?
