Battery Relocation Help Please
icer
  • Replies 46
  • Created
  • Last Reply
Top Posters In This Topic
  • Banned
  • Member For: 15y 5m 23d
just had a look. the organge 2 pin plugs under the headlights are clicked into place. took em out and put em back in and still not working. any other suggestions?
  • Banned
I noticed this unplugged but no idea where it plugs into as there is nothign reachable. Is it a boost/fuel sensor of some sort that AVO had reqired or something while doing mods to IC kit?
  • Member For: 19y 4m 29d
Hrmmm... The old battery earth only goes down through the fuse box, to a mounting point on the chassis.
Like I said eariler, look below for a earth wire which mounts to the panel below / behind the drivers side headlight. Its roughly where the AVO under battery pipe is routed. I suspect this may be a issue to all your wiring nightmares. Its a common ground point.
  • Banned
that was never removed/touched.
the one that has like a small tip lip on the terminal which also is the same on the passanger side.
