Oil Cooler
Billy Bunter
  • Member For: 19y 7m 13d
Hi BB,
What are you after, an engine or transmission oil cooler? Perhaps I have misunderstood your question, are you referring to a factory option? There are coolers available for both.. Just work out what you need..
Cheers,
Mal K
Edited by revheadrobbo
No need to quote above post
  • Member For: 21y 6m 26d
What they are for is to provide better cooling for the engine and trans oil. If you drive your car hard or hit the track then they are a good investment. Easy to install and not that expensive.
Benny
  • Member For: 16y 6m 23d
Its simple; :facepalm:
a system for keeping the oils at the right temperature. :spoton:
Because if any Oil gets too hot it starts to break down and loose its properties, becoming sh*t. :pooh:
So if you tow for a long period its a must.
Give the engine a good old punishing :3gears: its a must.
Even if you don't do those it still helps to maintain the engine and trans/gearbox for long and happy motoring. :icon_ford:
But even without it your just in the same boat as just about every other car out there.
  • 1 month later...
  • Member For: 14y 11m 22d
Benny
Thank you Benny, I am going to get one on my new falcon, kind regards Geoff.
