will-82 Member 427 Member For: 20y 3m 21d Location: sydney Posted 10/03/10 08:02 AM Share Posted 10/03/10 08:02 AM I use mobile 1 5w/50 in all my cars Link to comment https://www.fordxr6turbo.com/forum/topic/66776-servicing/page/2/#findComment-989740 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 13d Gender: Male Location: Probably above atmospheric pressure Posted 10/03/10 02:13 PM Share Posted 10/03/10 02:13 PM Castrol Edge 0w-40 as recommended by tuner. Link to comment https://www.fordxr6turbo.com/forum/topic/66776-servicing/page/2/#findComment-989918 Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 16y 2m 10d Gender: Male Posted 11/03/10 05:02 AM Share Posted 11/03/10 05:02 AM For the everyday driver with a fairly sedate turbo will be fine with a good quality synthetic oil. If you are running big power and fully built engines, then yes royal purple would be a nice place to start.Penrite will sell about $50 for 5L.But, if Ford recommend a 15w40 oil, why do people ignore this and use 0w40 or axw60 oil? I believe there is a thread here somewhere discussing the downsides to 0w oils for our engines... might be worth reading again. Link to comment https://www.fordxr6turbo.com/forum/topic/66776-servicing/page/2/#findComment-990055 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 13d Gender: Male Location: Probably above atmospheric pressure Posted 11/03/10 12:11 PM Share Posted 11/03/10 12:11 PM The technicals are all way over my head, I've gotten lost in debate threads many a time and still have no idea Link to comment https://www.fordxr6turbo.com/forum/topic/66776-servicing/page/2/#findComment-990232 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 15d Gender: Male Location: SE Melbourne Posted 15/03/10 03:45 PM Share Posted 15/03/10 03:45 PM The oil type depends on what brand you buy. Penrite looks pretty good. They even have oil for the ZFThis is from castrol website... Quote FORD BF Falcon XR6 Series, 4.0L 6 Cyl. Turbo Eng. Crankcase CASTROL EDGE SPORT 10W-60Service Refill Capacity: 6.6* Litres (See Note 645)Penrite Website..... Quote Make FORD (AUS) Model Falcon XR6 Turbo (Falcon BF Series) Engine PT Year 2005 - Application Recommendation Capacity (ltr) Engine (PT) Everyday Synthetic 10W40 6.6 Manual Transmission - (b) 2.1 Automatic Transmission (ZF 6HP26) SIN ATF 4.0 Differential SIN Gear 80 (a) 1.9 Coolant Premium AF/AB © 8.7 / 8.9 Brake Fluid First Choice Brake Fluid 525 0.5 May also Use SIN Brake Fluid Clutch Fluid First Choice Brake Fluid 525 0.1 May also Use SIN Brake Fluid Power Steering Power Steering Fluid 1.1 Link to comment https://www.fordxr6turbo.com/forum/topic/66776-servicing/page/2/#findComment-991423 Share on other sites More sharing options...
arm79 Donating Members 214 Member For: 16y 2m 11d Gender: Male Location: Melbourne Posted 17/03/10 04:01 AM Share Posted 17/03/10 04:01 AM On 11/03/2010 at 5:02 AM, seduced said: But, if Ford recommend a 15w40 oil, why do people ignore this and use 0w40 or axw60 oil? I believe there is a thread here somewhere discussing the downsides to 0w oils for our engines... might be worth reading again.If you read the Ford manual (mine is an FPV, so the manual may differ) it actually recommends a 15/40 mineral oil, which as we know is a big no no for these poor turbo engines.I'd expect they specify mineral to keep the advertised service costs down, when in fact the dealers usually put in a semi synthetic. In an FPV, a mineral 15/40 is used for the inital fill only, then its expected to be changed to a synthetic, but the book doesnt say that, and most of the dealers don't know that either.I started using the Castrol 10/60 because it was recommended by Castrol, and subsequently found out they worked with FPV to develop this oil specially for the FPV turbos. Reason being, it is a turbo, it runs hot and owners are expected to rape and abuse their cars, sometimes on a track (This is from FPV themselves). Whereas they recommend a Magnatic 15/40 or 10/30 for the XR6T's... Same engine, etc, etc, so go figure.If a 15/40 oils weight is 40 at 100 deg, what is it at 110 to 120 deg. 20? 30?So their theory is to start with a higher figure and when you do hit those temps, the oil doesn't thin out as much. At 120 deg it might be equivalent to a 40 weight.I have since put a Mobil 1 0/40 in, and I have noticed the engine feels a tad freer and gets sightly better fuel consumption, but after a general on road flogging, the oil pressure gauge sits alot lower then when using the Catrol oil. I know these gaugues arent meant to be accurate, but they do provide a general feel of how things are going.I did read that thread, and it was very imformative, and also continued on with my own research. So there is no set oil for these engines. Yes the 0 weight is a waste in our climate. But you need to buy what best suits your driving needs/style, not what the book says. Next time I do an oil swap, I'd prob consider the Nulon oil everyone else uses... But I do get concerned when I see the oil pressure gauge take a dive when I'm stopped at the lights.Also, if we all followed the book, chances are we'd see a shed load more failed turbos. Link to comment https://www.fordxr6turbo.com/forum/topic/66776-servicing/page/2/#findComment-991749 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 12d Gender: Male Location: Brisbane Posted 17/03/10 04:26 AM Share Posted 17/03/10 04:26 AM lol @ Ford recommended. As a bit of an analogy, who here runs the recommended tyre pressures? Link to comment https://www.fordxr6turbo.com/forum/topic/66776-servicing/page/2/#findComment-991754 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 18d Gender: Male Location: Earth Posted 17/03/10 05:30 AM Share Posted 17/03/10 05:30 AM On 10/03/2010 at 7:01 AM, revheadrobbo said: So whats the penrite worth per 5L bottleLast time I bought it, $85 per bottle.The joys of remote living. Link to comment https://www.fordxr6turbo.com/forum/topic/66776-servicing/page/2/#findComment-991788 Share on other sites More sharing options...
Full Monty Member 513 Member For: 17y 10m 14d Gender: Male Location: Melbourne Posted 22/03/10 10:49 PM Share Posted 22/03/10 10:49 PM Royal Purple is great, been using it for 4 years...But its hard to get, and around $95-$100 for 5 ltrs (only one autobarn in melbourne stocks it, and I wont say who coz you buggers will buy it all).But, there is a guy in melbourne, who imports the 1 quart bottles (950ml), a bit cheaper, you just buy a box of a dozen bottles or so at a time, just a pain at a service, as you have to open 7 bottles of the stuff for each fill.I wish it were more readily available. Link to comment https://www.fordxr6turbo.com/forum/topic/66776-servicing/page/2/#findComment-993808 Share on other sites More sharing options...
Guest XR09 Guests Posted 23/03/10 03:35 AM Share Posted 23/03/10 03:35 AM I always thought a 0w was for places where you had to use an engine warmer. Or it reved to 15,000+. I doubt it would stick to anything in our climate. Not too mention the tollerances of the I6. I use the penrite Sin 20w/60w in the FG. If I had a higher reving 4 pot turbo I would go down to the 15w. I think below that unless as I said you live in Tassie or the snow for winter, under a 15w in an I6 is not just over kill. It may not be the best for it. Link to comment https://www.fordxr6turbo.com/forum/topic/66776-servicing/page/2/#findComment-993881 Share on other sites More sharing options...
