KWIK F6 Donating Members 526 Member For: 15y 10m 28d Gender: Male Location: Adelaide Posted 08/03/10 09:21 AM Share Posted 08/03/10 09:21 AM Well I finally got my PLAZMAMAN Street Pro Spec 2 Intercooler Kit in the mail the other day....Arrived about 6 o'clock in the evening. I was so excited I ran straight to the shed and grabbed the tools and started pulling the car to bits.I was thinking to myself, Should only take an hour or two. Pretty simple swap over.. Well I was wrong..Midnight crept up and I was still trying to fit the damn hot side piping..Damn factory spring clamps in a C#*T of a place taking up all my time.Finally got all the old stuff removed and on with the new kit. Had to cut and extend the wiring for the OEM sensor.Not a hard kit to install just time consuming.In the end I installed a 450x350x90 Bar and Plate PLAZMAMAN IntercoolerHot side piping3" Cold Side PipingUnder Battery Cold Air InductionVery happy with how the kit looks and fits.No clearance issues at all.I added a Heat shield the rear of the POD to stop any water from finding its way through the wheel arches. Even managed to fit my transcooler above the intercoolerBig thanks to Alex and PLAZMAMAN for all his ongoing advice and help. Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 4m 30d Gender: Male Location: Perth, WA Posted 08/03/10 10:54 AM Share Posted 08/03/10 10:54 AM Did you have cut much to get the cooler in there? What size were the coolers inlet/outlet pipes?Cheers. Link to comment Share on other sites More sharing options...
KWIK F6 Donating Members 526 Member For: 15y 10m 28d Gender: Male Location: Adelaide Posted 08/03/10 11:54 AM Author Share Posted 08/03/10 11:54 AM Did you have cut much to get the cooler in there? What size were the coolers inlet/outlet pipes?Cheers.No cutting at all..Just had to push the air con line on the right of the car back about 2cm to center the cooler...Was easy.. Just had to be careful not to pinch the line.Outlets are 3" I think.. Its has the 3" Coldside piping and 2.75 HotsideHope this helps Link to comment Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 7m 4d Gender: Male Location: Aspendale, Vic. Posted 08/03/10 12:03 PM Share Posted 08/03/10 12:03 PM chop chop with a retune + results BEFORE AND AFTER! :D good work! Link to comment Share on other sites More sharing options...
KWIK F6 Donating Members 526 Member For: 15y 10m 28d Gender: Male Location: Adelaide Posted 09/03/10 03:21 AM Author Share Posted 09/03/10 03:21 AM chop chop with a retune + results BEFORE AND AFTER! :D good work!Cars going into Bruce Heinrich on the 11th of March for a new trans and re tune..Will post up Dyno sheets when I pick it up.. Link to comment Share on other sites More sharing options...
Turbo Ute BOOSTN Donating Members 182 Member For: 15y 1m 30d Gender: Male Location: Geelong Posted 10/03/10 08:52 AM Share Posted 10/03/10 08:52 AM nice kit, makes it easy that you didn't have to do any cutting, good idea with the Heat shield too. makes sure u post new figures once its tuned.. Link to comment Share on other sites More sharing options...
KWIK F6 Donating Members 526 Member For: 15y 10m 28d Gender: Male Location: Adelaide Posted 11/03/10 09:24 AM Author Share Posted 11/03/10 09:24 AM Well I picked up my car from Bruce this arvo...Car pulls like a train and shifts very nice with the new trans and hi stall. Bruce only tuned it to 305.4 @ 13Psi due to the tune being very sound all through the rev range...Car feels very quick and the gears are very snappy. Im happy with the result. Will wait a few months I think then pump a few more pounds of boost into it....Still has plenty of potential for more power.Ill post up the dyno sheet when the misses bring my printer home from me sisters.. Link to comment Share on other sites More sharing options...
SPIKO Gold Donating Members 1,924 Member For: 19y 10m 14d Gender: Male Posted 12/03/10 12:17 AM Share Posted 12/03/10 12:17 AM I run exactly the same kit in my Phoon, hat's of to Alex/Plazmaman for this kit awesome piece of work and capable of producing power Back to Back in any conditions... Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 4m 30d Gender: Male Location: Perth, WA Posted 12/03/10 01:18 AM Share Posted 12/03/10 01:18 AM wayne2106, good results. What setup did you run before going to the Plazmaman Spec 2 kit?I like this particular intercooler size because there is no cutting or moving AC lines to within a mm of them snapping. I run exactly the same kit in my Phoon, hat's of to Alex/Plazmaman for this kit awesome piece of work and capable of producing power Back to Back in any conditions... SPIKO are you running the 450x350x90 or 500x400x90 core on your 10sec BA?Thanks. Link to comment Share on other sites More sharing options...
KWIK F6 Donating Members 526 Member For: 15y 10m 28d Gender: Male Location: Adelaide Posted 12/03/10 01:40 AM Author Share Posted 12/03/10 01:40 AM I was running a monza set up..wasn't too bad but on a hot bad heat soak set in Link to comment Share on other sites More sharing options...
