MYBAXRT Member 158 Member For: 15y 10m 23d Gender: Male Location: nowra Posted 15/03/10 10:51 AM Share Posted 15/03/10 10:51 AM I had the same problem took the car in to the local ford it took them 3 goes to find what was up, it ended up being the coil pack. that was about 1 year ago but iam getting the same problem again. So iam going to get them to change the coils over and the spark plugs then it will be right as rain again.... Link to comment Share on other sites More sharing options...
dan(nthqld) Member 47 Member For: 15y 11m 13d Gender: Male Location: Townsville Posted 15/03/10 10:58 AM Author Share Posted 15/03/10 10:58 AM Did your car make the loud spool sound of the turbo? like pretty loud lol Link to comment Share on other sites More sharing options...
MYBAXRT Member 158 Member For: 15y 10m 23d Gender: Male Location: nowra Posted 15/03/10 11:03 AM Share Posted 15/03/10 11:03 AM no the turbo sounds the same.is your car stock? Link to comment Share on other sites More sharing options...
dan(nthqld) Member 47 Member For: 15y 11m 13d Gender: Male Location: Townsville Posted 15/03/10 11:05 AM Author Share Posted 15/03/10 11:05 AM yep no mods watsoever, apart from k&n panel filter Link to comment Share on other sites More sharing options...
MYBAXRT Member 158 Member For: 15y 10m 23d Gender: Male Location: nowra Posted 15/03/10 11:09 AM Share Posted 15/03/10 11:09 AM I think you will find its just your coil pack or your spark plugs just get them both done at lest you will know that there all new then Link to comment Share on other sites More sharing options...
kirjo Member 113 Member For: 15y 7m 13d Gender: Male Location: Brisbane Posted 15/03/10 01:07 PM Share Posted 15/03/10 01:07 PM Process of elimination mate. Go to Ford, get some F6 plugs part # AGSP22Z11. These are the best plugs and are only about 12-14 bucks each. If you are going to get your car tuned in the near future, gap them down to 0.75mm. This will save the labour getting it done later when you up the boost. Then go on ebay and get yourself some genuine Ford coil packs for dirt cheap. FORD BA - BF Brand NEW Genuine 6-Pack Ignition Coils - eBay, Other, Car Parts, Accessories, Cars, Bikes, Boats. (end time 19-Mar-10 04:40:50 AEDST)For about $250, you will get away with brand new genuine plugs and coils. If you go to ford for the coils, they will sting you about $500 for the set! Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 2m 6d Gender: Male Location: SE Melbourne Posted 15/03/10 01:27 PM Share Posted 15/03/10 01:27 PM There should be a small rubber hose going from the front bottom of your turbo to the actuator. Pull it off and spray a good amount of wd40 down it then connect it back. Take the car for a drive and see if it improves. If it doesn't then it’s probably the plugs or packs but could also be the fuel filter. Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 2m 6d Gender: Male Location: SE Melbourne Posted 15/03/10 01:29 PM Share Posted 15/03/10 01:29 PM Also your cat may have collapsed. I'm no mechanic but they are the things I would check Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 2m 6d Gender: Male Location: SE Melbourne Posted 15/03/10 02:51 PM Share Posted 15/03/10 02:51 PM Sorry I said actuator but meant solanoid. Wont let me edit the post. Link to comment Share on other sites More sharing options...
dan(nthqld) Member 47 Member For: 15y 11m 13d Gender: Male Location: Townsville Posted 16/03/10 10:41 AM Author Share Posted 16/03/10 10:41 AM yea I have already done that to the solenoid. Having a really good look at it this weekend. will pull off every pipe and inspect, and also have a good look at plugs and coils. Link to comment Share on other sites More sharing options...
