  • Member For: 15y 3m 4d
  On 04/03/2010 at 8:00 AM, F6turbo said:
Throw a dyno sheet up of the 4th tune if you have it, 320 seems a bit low for 17psi and the mods you have to it.
When you get used to the car 320rwkw isn't gonan feel all that quick.... :buttrock:
yer ill scan one to my email and post it up ..... so you guys think I should be getting more from this with these tunes ?? .... I thought it was pretty good to be honest ... but being that ive only had the car a couple weeks I guess im not to sure on what to expect ... but yer like I said ill defo be taking it to the local xr6t guru when I get some extra money ....just to see what they think about the tuning of the vehicle !
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
  • flame magnet
  • Member For: 17y
out of a ba it would be about right- but bf's tend to be able to produce more- but its like anything, some cars are freaks when it comes to making power, some are average and some are lower... :buttrock:
also dyno's can read different- you may take it to another shop and make 345....
Edited by fordriver1
yer but saying that I I didnt really go out to buy someting that was stupidly fast
I wanted something that was tidy with low k's and a good price , it just so happens that this one met all that criteria and some with the mods done to it, it only has 38 thou on the clock came with the 20's hardcover and front bar and the car is in prestine condition so all in all im pretty happy with the package for 26k .... my real main concern was the amount of boost it was running. but seems to be 80% saying it should be ok , its not like im strapping it around hitting 17 psi every gear change
  • Member For: 18y 11m 13d
I'm not saying theres anything wrong with your car, just it could probably make a bit more with the current set up. As long as you are happy with it that's all that matters. 17 psi isnt crazy high boost for these cars, just after a good hit make sure you let it cool down for a bit before shutting it off.
  • Member For: 16y 6m 5d
The higher the boost you run the hotter the engine will run... 17psi doesnt sound over the top but I would have expected more with your mods... I run 10psi max for 330rwkw and have less mods... :buttrock:
hmmm yer ive read a few posts where people have fewer mods and more kw , I hooked up a boost gauge on the weekend, the guy I bought it from was saying it ran 17psi but the gauge is reading 15-16psi so yer not to sure on that one .... like I previously said im happy with it the way it is at the moment but will defo be taking it in to have a squizz at the tune what can be done to give it some more grunt when I have some more cash , im getting married in August so that's chewing up a fair bit of our funds at the moment
but once that's done , gonna look at getting a plazaman plenum and a few other things to spice the uterus up a bit more :3gears:
but yer im super happy with it at the moment there isnt much on the streets that's come near these things when they have a few mods
best bang for ya buck I reckon :stirthepot:
thanks for you input into the topic though mate
nah mate all good didnt take it that way .... I agree with ya after reading up on a few forums you would think with the mods I have it would have a bit more RwKw. guess ill have to start putting some cash away to have in dyno'd and have the local guru check out the tune and see what he thinks.
and yer I defo let the car idle for a minute or so before shutting it off.
Thanks heaps for the advise mate its all appreciated :stirthepot:
  • Member For: 15y 11m 22d
Its probably redlining by the sound of it revving it to high, I've had this happen to me when I leave in 1st or 2nd gear to long it redlines & starts to back firer or the traction control is on & the light flashes on the cluster.....
  • Member For: 16y 5m 25d
Yeah the backfire is either TC, either limiter or the computer dumping fuel through the engine to cool your turbo.
Just take it easier.
Edited by Paulie2256
