  • Member For: 19y 6m 10d
I got a atomic motor and its great I now have had a second one built because of tuning issues with cams and everything. standard pistons are quieter yea but with a good tune I wouldnt be worried about my motow pushing 450rwkw. y go to all the troubly and still have the thought in the back of your head
  • Member For: 22y 1m 23d
There are two types of piston failures. The catastrophic where the piston totally breaks apart and the rod makes a mess of the cylinder and there is the non catestrophic where you may break a ring land or put a hole in the piston, usually thru bad tuning. Usually not a big deal. Just put a new piston in.
I have yet to see a catastrophic failure in a BA turbo piston. I have also pushed around 500 rwhp thru a stock ED piston and only ever had ring land failure. The current generation of ACL performance pistons is surprisingly good.
If anyone has had a catastrophic failure lets hear about it.
  • Member For: 20y 4m 19d
Jeez, it's bloody quiet, isn't it.
I can't believe no one's had a catastrophic engine failure. Makes me wonder why people are forking out the big bucks for the built motors :spoton:
  • I see red
  • Member For: 22y 5m 7d
A couple of years ago Jeff DBOSS punched a hole in the block of his modded XR6T. I think it may of been the rod failing not the piston though. Maybe DBOSS can enlighten us as to what actually happened and how much power he was running.
  • Moar Powar Babeh
  • Member For: 19y 8m
You know something you may just be right its always best to let something fail before putting any work into making it stronger....this from a guy who was preaching about rods out the side causing eng bay fires a few months back... :spoton:
Edited by hiddeous
  • Formerly Turbo6
  • Member For: 22y 4m 16d
I forked out money because I wanted to make my bottom end stronger and more durable - I learnt by other peoples experiences and what I believe is a pretty common sense approach to powering up. I didn't want to end up a tilt tray with a busted engine or worse
How long would a stock bottom end last with 400+rwkw's? I certainly did not want to find out the hard way and be worried everytime I put my foot down. What if you wreck the head when a rod lets go or a piece of piston goes through it?? :blink:
  • Moar Powar Babeh
back on topic. I decided to try out some of Royal Purple eng oil that seems to be all the rage at the moment and im quite surprised at the difference it made to the cold rattle. The motor used to produce piston noise between aprox 1100 and 1600 under no load. the range has reduced to aprox1300 to 1500 rpm and is barely audible from inside the car,(although it was always pretty hard to hear it over the t56 anyway....) the oil was quite expensive but seems to be doing the trick at the moment. Apparently 10000k's is the recommended interval for the 5w30 with a filter change around 5000k's. So although the oil is basically twice the price of regular oil, the extended interval (i would normally change it at 5000) may mean it works out around the same. I have a clean control sample and i'l be getting another sample done in 5000k's to see how its holding up.... <_<
  • Team Bute
  • Member For: 21y 10m 8d
I can't believe no one's had a catastrophic engine failure. Makes me wonder why people are forking out the big bucks for the built motors <_<
I think many of us are happy enough with the performance gains with the stock bottom end.
11's are achievable quite easily now, with aftermarket addons and a good tune, and that's exceptional for a street car.
Going quicker becomes a costly exercise.....
I think most guys who are powering up their T's are aware that 330 rwkw is around the mark for maintaining reliability with the stock bottom end.
Most workshops have been responsible enough to tell their clients that if chasing more power, a stronger rod (at the least) is required.
I guess, if replacing rods, may as well set up the whole bottom end properly whilst its off the road... (stronger balanced crank, rods and pistons)
That takes the cost of upping the ante quite significantly.
Then there is the requirement for a roll cage if breaking into the 10's.... more cost.
Gearbox limitations are also holding back many from chasing more power.
Once the gearbox limitation is rectified, I think quite a few more T owners might exercise their wallets for the next benchmark of 400+ rwkw and easy 10's!
cheers
tom
  • Mushroom
  • Member For: 21y 8d
I know of at least 5 in QLD that have punched a rod through the block - 3 of which came from the same tuner - I'll let you work out who it is for yourself.
There have been a couple that have posted pics on here of the damage - others prefer to keep it hush hush.
For the record... They were tuned by "local QLD tuners".
Edited by Adam
