  • Member For: 19y 1m 17d
I think your oil is too heavy, and though this may not be the cause of your noise, I have found that you want to stay below 40 viscosity (I run a mix of 30 and 40 weight oil to achieve something around 35)
I have found that 50 or 60 viscosity oil makes engine more noisy, as I think not enough oil escapes from bearing journals to adequately lubricate bottom of bores, thus causing pistons to 'slap' from side to side.
My 2c worth - Good luck with getting this fixed.
Hi Ninka,
Noticed your running Cosworth Pistons within your Signiture attached below????
What are Atomic's Cosworth pistons like for noise when cold????
2002 BA XR6 Turbo, ZF 6 Speed Auto, XFT Tuned 371 rwkw, Nizpro Kit, Atomic Rods, Cosworth Pistons, Walbro Fuel Pump, K&N Pod Filter, 4" SMB dump and 5" cat, 2 x 2.5" SS Quad Tip Exhaust, 'Premium' Brakes w. 5000 rotors, Whiteline Anti Roll Bars
Cheers
Anyone running Atomic's Cosworth pistons in their engine?
If so how many km's has your engine done and at what RWKW???
What is the operational noise of Atomic's Cosworth pistons like at idle?
Thanks
  • Member For: 15y 4m 23d
Hey Simon im running an atomic motor with the cosworth pistons, the motor is relatively quiet at idle but does have some timing chain rattle which sucks.
done 3000km and is running 498rwkw
Edited by retro-xr6t
