Quasi XR6T Member 153 Member For: 12y 4m 4d Gender: Male Location: Canberra, Australia Posted 27/04/13 07:55 AM Share Posted 27/04/13 07:55 AM Yeah, Seres seem to be doing some good stuff down there, but Mornington is just a bit out of my way. Link to comment https://www.fordxr6turbo.com/forum/topic/66619-atomic-motors-merged-topic/page/35/#findComment-1384282 Share on other sites More sharing options...
spinr33 Donating Members 964 Member For: 13y 9m 19d Posted 27/04/13 07:15 PM Share Posted 27/04/13 07:15 PM Its only $150-$250 freight to pallet an engine mate not that expensive Link to comment https://www.fordxr6turbo.com/forum/topic/66619-atomic-motors-merged-topic/page/35/#findComment-1384397 Share on other sites More sharing options...
Adamfiza80 Member 74 Member For: 12y 2m 6d Gender: Male Location: Newcaslte Posted 02/09/13 11:55 AM Share Posted 02/09/13 11:55 AM Hey guys. Just got brad at Atomic to rebuild my fg f6 engine. I would like to report that my engine, although runs fine, is just noisey. Pretty quiet when cold but noisey when warm. Which goes against what we normally hear about forged internals. Im running recommended weight oil of 15w 50 and have had the timing chain etc upgraded, also head ported n serviced, heavy duty valve springs but oem lifters etc. Motor has been balanced and blueprinted as per his specs sheet. Just want to know if this id acceptable? Spent alot of $ on this. Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/66619-atomic-motors-merged-topic/page/35/#findComment-1420743 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 2m 5d Gender: Male Posted 02/09/13 12:35 PM Share Posted 02/09/13 12:35 PM It may not be piston slap if only on warm. Ask him what piston to bore clearance he runs. Nowadays they are pretty tight with forgees depending on brand. The only other thing is valvetrain noise. When you start doing head work you gotta be careful with lifter clearances. Link to comment https://www.fordxr6turbo.com/forum/topic/66619-atomic-motors-merged-topic/page/35/#findComment-1420763 Share on other sites More sharing options...
Adamfiza80 Member 74 Member For: 12y 2m 6d Gender: Male Location: Newcaslte Posted 02/09/13 01:11 PM Share Posted 02/09/13 01:11 PM Yeah not much was mention on the spec sheet regarding head work except that it had 2 valves replaced that may have been damaged. Since it was all part brad reseated valves, cnc ported and serviced head. Do heavier valve springs relate to more valve train noise. If so, it could b that. Once revs go past approx 1600rpm the noise disappears. The noise is always the same and moves with revs till that 1600 point. Its also not intermittent. Any ideas are welcome. Im going to take the car to brad next week for him to see. Link to comment https://www.fordxr6turbo.com/forum/topic/66619-atomic-motors-merged-topic/page/35/#findComment-1420799 Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 9m 17d Posted 02/09/13 09:32 PM Share Posted 02/09/13 09:32 PM could it be timing chain noise ?? Link to comment https://www.fordxr6turbo.com/forum/topic/66619-atomic-motors-merged-topic/page/35/#findComment-1420826 Share on other sites More sharing options...
welshy_89 Member 131 Member For: 13y 10m 10d Posted 02/09/13 10:54 PM Share Posted 02/09/13 10:54 PM Or possibly cam phaser Link to comment https://www.fordxr6turbo.com/forum/topic/66619-atomic-motors-merged-topic/page/35/#findComment-1420848 Share on other sites More sharing options...
Adamfiza80 Member 74 Member For: 12y 2m 6d Gender: Male Location: Newcaslte Posted 03/09/13 04:00 AM Share Posted 03/09/13 04:00 AM Spoke to Brad and we sort of agree that it could be timing chain noise. Find out more next week guys. Will keep you posted. Link to comment https://www.fordxr6turbo.com/forum/topic/66619-atomic-motors-merged-topic/page/35/#findComment-1420928 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 5m 12d Gender: Male Location: Perth, WA Posted 04/09/13 04:48 AM Share Posted 04/09/13 04:48 AM I think your oil is too heavy, and though this may not be the cause of your noise, I have found that you want to stay below 40 viscosity (I run a mix of 30 and 40 weight oil to achieve something around 35)I have found that 50 or 60 viscosity oil makes engine more noisy, as I think not enough oil escapes from bearing journals to adequately lubricate bottom of bores, thus causing pistons to 'slap' from side to side.My 2c worth - Good luck with getting this fixed. Link to comment https://www.fordxr6turbo.com/forum/topic/66619-atomic-motors-merged-topic/page/35/#findComment-1421208 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 4m 18d Gender: Male Location: Christchurch, New Zealand Posted 04/09/13 06:26 AM Share Posted 04/09/13 06:26 AM The weight of the oil is to do with temp. If you are racing you want to run a higher viscousity as a 60 will be the same as a 40 at the higher temps you will see when giving the engine that much stick for a long period.If however you are generally driving about normally with the occasional bit of spirited driving then you should stick with the manufacturers recommendation. Link to comment https://www.fordxr6turbo.com/forum/topic/66619-atomic-motors-merged-topic/page/35/#findComment-1421240 Share on other sites More sharing options...
