  • Member For: 20y 3m 20d
  O2STOCK said:
  Adam said:
A couple of guys from WA have shown that the stock piston can handle it.
They even went from forged back to stock due to the rattling.
As to the point that they become a liability I'm not sure.
Maybe the $2500 bottom end is the go from FORD ? for 300-350 RWKW
Ideas ?
That my friend is probably the most cost effective solution. Any of the engines from 05/06 are basically a F6 engine, which should be capable of supporting 350-400rwkw dependant on the tune.
  • Member For: 20y 8m 8d
  M6 XR6T said:
So what do you think causes the rod bolts to fail? I'm of the opinion that over-revving the engine has a large part to do with it. The same can be said about oil pump gear failures.
Probalbly less common but severe engine braking could also cause it, that's why its best to blip the throttle on the gear down changes when giving it a hard time!
  • www.australianflag.org.au
  • Member For: 19y 9m 7d
Ideas ?
When in 05 did this happen, my engine is a late 05 BA Mk 11.
Scotty
I will get month when I get home.
  • My new toy
  • Member For: 22y 2d
Just rang ford spare parts the ba xr6t bottom end is different to the bf xr6t bottom end which is different to the bf f6 bottom end so I really think that you are tacking a risk buying a ford bottom end.
Better to rebiuld your own motor with rods and pistons.
Ian
  • Member For: 21y 2m 23d
Ian
did they tell you how they all differ?
  GOLDIE said:
No they are trying to find out.
Ian
thanks goldie :spoton:
FORD are trying to find out?? shouldnt they know :tease: No wonder a lot people have 2nd thoughts about servicing at ford etc
Edited by jetute
  • My new toy
It's the spare parts thing does not tell them the difference it just gives them different part numbers.
Ian
  • 3 weeks later...
  • Member For: 18y 9m 9d
How nosiey are atomic short engine done 750km still there giving me the sh*ts 1500rpm to3000rpm just rattes like some thing not right in there pulled rocker cover to make sure it was't the timing chain but all good in there
