HI PSI Member 1,586 Member For: 18y 10m 23d Gender: Male Location: Central Queensland Posted 26/02/10 09:00 PM Share Posted 26/02/10 09:00 PM I currently have the car in a million pieces, removing and replacing the turbo housing with a ported one. I am alos fitting my Rapid V3 cooler and injectors at the same time. Is is possible to remove the injectors and fit the Dekka's withoout removing the Throttle body?? Link to comment https://www.fordxr6turbo.com/forum/topic/66541-can-injectors-be-changed-without-removing/ Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 17y 1m 14d Gender: Male Location: Blacktown! Posted 26/02/10 09:38 PM Share Posted 26/02/10 09:38 PM No. from memory there is 2 bolts that sit under the throttle body that holds the fuel rail. Without undoing the fuel rail you cant remove the injectors. Why do you not want to undo the throttle body? with the right tools, its just 4 hex headed bolts holding the thing on. And then the wiring for the TPS to remove. Would take all of 5 mins to undo Link to comment https://www.fordxr6turbo.com/forum/topic/66541-can-injectors-be-changed-without-removing/#findComment-986047 Share on other sites More sharing options...
