BIONIC^F6 Member 41 Member For: 17y 4m 18d Gender: Male Posted 26/02/10 08:30 PM Share Posted 26/02/10 08:30 PM Hey Guys,ive been through a number of the threads already in search of some help with the rgb converter. I have come to a conclusion but I would like to really pin point what info I need to start installing my carputer again to the icc. can some one please assist with the questions below, - im most likely going to use the vga to cga rgb converter, I know some of the guys here are using this type. can some one assist with the wiring. a quick wiring diagram will be awesome - would a standard vga pci card run the factory icc screen, I have read you need a arcade vga. can some one help with this even a link will be good.VGA to CGA - RGB Converter - Converters - Arcade Video Game Sales by Highway Entertainment Link to comment Share on other sites More sharing options...
BIONIC^F6 Member 41 Member For: 17y 4m 18d Gender: Male Posted 01/03/10 11:02 AM Author Share Posted 01/03/10 11:02 AM can anyone assist??? Link to comment Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 16y 9m 11d Gender: Male Location: Greenvale, Victoria Posted 02/03/10 07:53 AM Share Posted 02/03/10 07:53 AM You not having much luck.There was a cble on Ebay. $49 but maybe worth it. Link to comment Share on other sites More sharing options...
ENVYOSXR Loves boost Donating Members 266 Member For: 15y 8m 19d Gender: Male Location: VIC Posted 03/03/10 02:17 AM Share Posted 03/03/10 02:17 AM Looks like this is some sort after info ill see what I can do for you guys. Ill try pull mine apart and write it all down for you. Link to comment Share on other sites More sharing options...
BIONIC^F6 Member 41 Member For: 17y 4m 18d Gender: Male Posted 04/03/10 01:17 AM Author Share Posted 04/03/10 01:17 AM ENVY that would be awesome if you can do that. Link to comment Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 16y 9m 11d Gender: Male Location: Greenvale, Victoria Posted 17/03/10 02:24 PM Share Posted 17/03/10 02:24 PM Big BUMP!!!! Link to comment Share on other sites More sharing options...
MeatWod Member 51 Member For: 17y 9m 3d Gender: Male Location: Baldivis Posted 18/03/10 10:47 AM Share Posted 18/03/10 10:47 AM (edited) Some video cards are able to run the screen with the assistance of power strip but because the screen hz isnt a standard sort of number in regards to pc monitors not all gfx cards can supply the correct signal, so arcade vga is your best bet or the RGB to CGA convertorIm currently using the RGB to CGA Convertor out of my asus eeebox as for the wiring diagram I followed the info on this pageCarputer for the Ford's Premium ICCthe diagram is for hooking it straight up to your gfx card but the pins are labled so you can work it out for the RGB convertor cable as they are labelled in the manual and also colour coded Edited 18/03/10 10:55 AM by MeatWod Link to comment Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 16y 9m 11d Gender: Male Location: Greenvale, Victoria Posted 18/03/10 12:33 PM Share Posted 18/03/10 12:33 PM Foryour info. Got an email back from ASL today. They dont supply the cables any more for the Ford ICC. Link to comment Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 16y 9m 11d Gender: Male Location: Greenvale, Victoria Posted 29/03/10 02:39 AM Share Posted 29/03/10 02:39 AM Thanks for that but it doesnt show the wiring fromt he converter card that we have.Bionic I sent you a pm.Cheers. Link to comment Share on other sites More sharing options...
MeatWod Member 51 Member For: 17y 9m 3d Gender: Male Location: Baldivis Posted 08/04/10 08:48 AM Share Posted 08/04/10 08:48 AM yeah it doesn't, but it dose label all the pins on the car's plug and your convertor should have came with a manual labelling its pins? it' also labelled on the PCB anyway thouRed to RedGreen to GreenBlue to BlueGround to GroundSync to Syncinstall a switch on the ground if you want to be able to switch your video on and off Link to comment Share on other sites More sharing options...
