destino Member 25 Member For: 17y 5m Posted 23/02/10 10:56 PM Share Posted 23/02/10 10:56 PM Hi all,Have a slight problem,the auto driving lights do not automatically turn on at night any more.Ive just noticed this the other day.Any ideas? Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 11m 17d Gender: Male Location: Christchurch, New Zealand Posted 24/02/10 01:17 AM Share Posted 24/02/10 01:17 AM Maybe the sensor on the dash is busted. It is the little ball looking thing front centre of the dash between the air outlets for windscreen. I would guess that if it stopped working it would not activate the lights. Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 10m 21d Gender: Male Location: Sydney Posted 24/02/10 01:19 AM Share Posted 24/02/10 01:19 AM is your car a FG ?If so there is an adjustment for the sensor, if it is a BF then the sensor would be stuffer Link to comment Share on other sites More sharing options...
dashturbo Donating Members 280 Member For: 16y 4m 27d Gender: Male Location: Watsonia Posted 24/02/10 03:30 AM Share Posted 24/02/10 03:30 AM Hi all,Have a slight problem,the auto driving lights do not automatically turn on at night any more.Ive just noticed this the other day.Any ideas?just to clarify, headlights or driving lights? you can get your foglights to come on automatically by turning the knob on the RH indicator stalk, that's also how you turn on the auto headlights. Link to comment Share on other sites More sharing options...
White Knight Donating Members 73 Member For: 15y 2m 15d Gender: Male Location: Sydney Posted 26/02/10 08:00 AM Share Posted 26/02/10 08:00 AM It is not necessarily your sensor, although this can play a role.The automatic headlights didn't work in my BF II for some time, until NONE of the driving lights would work whatsoever.The "combo switch" was replaced, I believe this is Fraud Service speak for the indicator stalk, or a component inside that stalk. Once this was changed, the lights operated perfectly (including the auto lights you are asking about). Link to comment Share on other sites More sharing options...
destino Member 25 Member For: 17y 5m Posted 02/03/10 05:57 AM Author Share Posted 02/03/10 05:57 AM So can be either sensor or "combo switch"?Any ideas how to find out which it might be?It is a 2005 BF xr6tThanks for the replies guys Link to comment Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 5m 28d Gender: Male Location: The 8th Dimension Posted 02/03/10 06:54 AM Share Posted 02/03/10 06:54 AM It is not necessarily your sensor, although this can play a role.The automatic headlights didn't work in my BF II for some time, until NONE of the driving lights would work whatsoever.The "combo switch" was replaced, I believe this is Fraud Service speak for the indicator stalk, or a component inside that stalk. Once this was changed, the lights operated perfectly (including the auto lights you are asking about).Sounds about right, replace the sensor after the auto lights stopped working and that did not fix the problem, so more than likely it was the switch gear. Not worth fixing at the replacement price of the switch. Link to comment Share on other sites More sharing options...
destino Member 25 Member For: 17y 5m Posted 02/03/10 09:13 AM Author Share Posted 02/03/10 09:13 AM haha, should I even bother to ask how much? Link to comment Share on other sites More sharing options...
Recks02 Member 2 Member For: 16y 6m 23d Posted 11/06/10 01:28 PM Share Posted 11/06/10 01:28 PM (edited) The auto headlights stopped working in my '07 Territory too and I got quoted $350 to replace the combo switch (warranty lapsed by 3 months, typical).I decided to have a look at the combo switch and found that a light grey wire at the base of the indicator stalk has come off. When you pull all the covers off you'll see that the wires are pretty tight when the stalk is moved up and down, so I'm assuming that this tension is what caused the wire to break off.I haven't bothered to fix this yet but nothing a bit of wire and solder won't fix.Hope this helps. Edited 12/06/10 01:38 AM by RHR No need to quote above post. USE FAST REPLY Link to comment Share on other sites More sharing options...
