  • Member For: 21y 9m 15d
I put the clear film on them , going fine. Don't be concerned about measurements, get some greaseproof paper or light paper, trace around it when holding into the light.
Remove and use that as your template. Easy as.
  • Replies 23
  • Flaccid Member
  • Member For: 22y 18d
  Quote
xr6ikness Posted on Oct 2 2003, 04:59 PM
  after the weekend cruise I have a driver's side cracked, anybody know the replacement cost?
something like 98 for the drives side and and 94 for the passenges side, Why the difference? I have no idea.....Try a serch, I seem to remember someone comming up with a cheaper replacement part that's identical (for about $50)
  • EVO 9 SUPPORTER
  • Member For: 22y 2m 10d
Both sides are exactly the same. Replacement cost is $97
Cheaper alternative is no longer available. Repco doesnt
stock it anymore. Easy to install once you pull the sump
guard off.
  • Flaccid Member
  Quote
guard off.
well I guess my dealer is telling me porkies, as I just paid 95 for the left and 98 for the right just two weeks ago :huh:
not that I care...I got out of paying $1.00... :lol:
Guest PhilH
  • Guests
Agreed with the template idea, I actually oversized mine (on purpose) and then gently cut them with a Stanley knife once they were on. You're supposed to run the lights hot before application, then once the 3M film gets up to temperature it cuts like butter.
Don't be too concerned about seeing some adhesive imperfections when you first put them on, it takes approx 2 days for the glue to dry perfectly clear. Take care to remove the air bubbles though.
Can't even see them once they're finished, and the foggies are in perfect condition (mind you only 1500km so far - but working on them every day).
  • I'm Back!! Thats right, long over due! :)
  • Member For: 22y 7m 4d
Sounds good. I might do the 3M film thing....just for stone protection more than anything else.
This only sounds like it is happening to the guys that have the flood lights on a lot of the time. No problems here and the only time I have them on is when I need them......I.e.: Heavy rain or thick fog. The only thing I have noticed is that the spotlights on our XR are a lose fit, you can wiggle the light slightly, maybe the ones that are cracking under heat expansion are more of a tight fit before they are used? Just guessing.
  • Flaccid Member
  Quote
Not guilty you honour:
I've lost two, got 8,000k up and never use them. They're down low and catch stones.
