  • Member For: 15y 9m 11d
My 380 rwkw tune which was my first one I did, had this light on all the time. I took it to ford and they said it was the exhaust with the emission senor they said dont worry about it
  • Member For: 15y 6m 29d
If I'm not mistaken, that MIL only reports errors with emission parameters, which can mean either two class of "problem":
1. Your car is not meeting the emission standards programmed into it as acceptable.
2. Your emissions diagnostic equipment I.e. sensors, associated wiring may be faulty, damaged, etc.
When you are running big power, option 1 is a more likely scenario.
Oh, there is a third type of problem indicated by the MIL: Your cat is about to melt. According to the manual the MIL "flashes at a rate of approximately one flash per second". Fail.
If the engine isn't receiving the correct information from the oxygen sensors it will substitute it's own values. I don't know if this is usually changed by a tuner (or if it CAN be changed), but in a stock car if I'm not mistaken it generally means your car runs rich at idle and lean while driving (which is not good over time).
  • Member For: 16y 4m 9d
I've just had the MIL engine light turn on on my car and it won't turn off. I walk to work at the moment and I haven't been using the car much for the past few months. The petrol at times has been in the tank for up to a month before refuelling. When the light first came on the car was idling very rough. After a short drive it was idling smoothly again but the light is still on. The car doesn't feel like it has lost any power - could the problem be a build up of crap in the fuel or engine??
Cheers
Edited by adrian_celati
